DAIZEN control arm bushings installed!
Guest
Posts: n/a
WOW! - total improvement over the stock worn out bushings.
Notes-
* The front end as a whole is much tighter - don't mistake this for uncomfortable. I'd actually say that driving on worn out stock bushings is more uncomfortable! Overall control of the car is a lot better than before.
* That 'feels like new' ride. Ever drive a new car and notice how repsonsive and soft the front end of the car is? All that is restored with these bushings.
* Improved braking feel. I'm not exactly sure why, but it probably has something to do with how much freeplay worn out bushings give the control arms. With the Daizen bushings that freeplay is eliminated allowing the suspention to operate correctly as if new.
* Better cornering and control (!!!) When turning the car goes where ever you want it to go.
* Overall stability. From the street to the freeway the doens't wobble or vibrate. At 110 it was really stable.
* SAFETY concern, the suspension goes beyond shocks and springs and must be maintained.
Anyway, I don't think some people really know how different the car drives. For the enthusiasts like us these are a must. To anyone who says they are too stiff, I don't see any valid reason since the majority of people are replacing OLD deteriorated bushings.
I don't really see any bad side to getting these awesome bushings, besides the compelxity of the job which may leave your mecahnic a little tired. :-)
Total cost : $600 at TM Engineering. $100 for the bushings and $500 for labor. Thanks to the guys over at TM, and just as important, Daizen for making such a great product.
Notes-
Just the replacement of the four arms alone calls for 10+ hours of work. I don't know where you can reference that $500 is too much for the labor. Tack on another 2 hours or so for the work to actually change the bushings.
If you were replacing the arms (which would be pretty much the only other alternative, the parts-only cost of the four arms is over $1500 and the "expensive" argument seems even more pointless.
Nothing on a car lasts forever, but luckily Lexus cars' parts usually last longer than pretty much any other car on the road. Just a fact of life and if that can't be dealt with, you'll just be putting around in a car that is falling apart.
Thanks for sharing your impressions, Lee. It sounds like these bushing do a great job replacing and probably far improving the oem components. I know the guys in the SC forum have been very impressed with these as well. One question, do you have any squeaking going over speed bumps?
Rich
Rich
Is there something very unusual about the Lexus control arm bushings that makes the labor so intensive? Because I am pretty sure that Sears auto centers will replace control arm bushings for $75
I've replaced the upper control arm bushings with the Daizen bushings which was obviously needed.
Regarding the lower control arm bushing: did you follow the recommendation on the Daizen instructions on removing the OEM bushing by heating and melting the rubber from the metal of the original bushing or did you just press the rubber out without using heat?
Just got new bottom ball joints in and will replace both at the same time I do the lower control arms.
For any of you planning to install the bushings yourselves: You should know that the control arm is quite thin and you can easily damage or crack the arm while pressing the bushings. Be carefull.\
If you plan to have it installed at Lexus dealer, you need to make sure that the ball joints are still in good condition, because it's expensive if you have to do it again several months down the road. I guess that's why Lexus doesn't sell the bushings and the ball joint for the upper control arm separately.
tvd51
tvd51
ive noticed that alot of people complain about the front and rear UPPER control arm bushings usually going bad, but i havent heard any complaints about the lower control arm bushings going bad. Of course if you buy the bushing set u would replace them reguardless if they are bad or not but has anyone come across or heard of the lower control arm bushings going bad?? thanks
