94 ls400 headlight replacement
I feel like an idiot that I cannot complete this task being that I am farley mech inclind. I have only had the car a month not sure where to start on the headlight bulb replacement. I have searched and came up w/ nothing and it is not in my owners manuel TIA Tyler
Here is a link from when I changed my headlight. Hope this helps.
https://www.clublexus.com/forums/sho...ighlight=kjbro
well not as easy as replacing a bulb in another car. but then again not that bad either.
simply unscrew the headlight assebly, three bolts in front, one in the side take it out and replace the bulb. But before you do that you'll have to take out the side light assembly which is pretty simple and requires one screw to be removed from the top end.
BCT
06-29-18 08:53 AM
shroomysou
20
02-29-16 07:22 PM
