Iridium spark plugs
Anyone has used iridium spark plugs on 1st generation of LS400 ? Any performance or mileage gain that justifies the additional cost ? Both Denso & NGK have iridium spark plugs but I don't know if they're compatible with LS400. Any idea ?
tvd51
tvd51
tvd51
tvd51
NGK has two types of platinum spark plugs:
- Laser Platinum: (recommended by Lexus manual) The platinum tips on both ground and center electrodes and they're welded using laser.
- G-Power Platinum: platinum tip on the center electrode only and not laser welded, but it costs less than half of Laser Platinum.
Anyone has used both types of these spark plugs ?
tvd51
tvd51
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Since I'm about to do a tune-up a needed to buy spark plugs. I was all set to buy the NGK platinum ones when I saw that the iridium plugs were about the same price. I ended up getting the NGK IX iridium plugs, we'll see if they're better.
http://www.ngksparkplugs.com/product...420&country=US
Earl, when you install the new spark plugs, try this hot rod tip:
Try different plugs until you have the electrodes opening facing the intake valves ---> more direct exposure between spark and fuel/air mixture ---> better combustion ---> more power.
tvd51
tvd51
I replaced the spark plugs with NGK G-Power Platinum (the less expensive ones compared with Laser Platinum). The car runs better, partially because the old plugs were under-torqued.
Earl!, what happens with your iridium plugs?
tvd51
tvd51
