Noise problem Solved!!!!
Gentlemen-To give you an update regarding the suspension noise I was having and the solution. To be more specific on the noise, it only occured going over sharp bumps and slamming on the brakes. Regarding the brakes, going forward only 1-2 mph and then slamming on the brakes would produce a huge, harsh cluncking sound in the front. Took it to my local mechanic and he brought in on the lift and found that the front strut rod's was worn. He called the Lexus dealer and talked to the parts guy, he indicated that this was most likely the problem as they replace a lot of these. Sure enough that solved the problem, the cost for that was $164 for each strut rod and $87 to put both on.
As you may also know I was debating on replacing my front and rear struts. I would describe the ride as floaty but did not have anything to compare it too as it was this way when i bought 1.5 yrs ago with 58K. I decided to have my front and rear struts replaced along with the front and rear strut mounts, expensive but wanted to see how much it improved the ride. I have heard that sometimes if you don't replace the mounts, if they're worn the can make noise. The Lexus front struts cost $183 for 2 and 2 mounts cost $237, the Lexus rear struts cost $163 for 2 and the two mounts cost $267.
Boy what a difference it made in the ride and handling, the front end no longer nose dives when braking and it doesn't feel like a boat lifting out of the water when i accelerate. The overall handling is improved greatly, the car doesn't float anymore and feels much more athletic. The front end actually sits about .5 to .75 inches higher than before, i am sure it may drop a little after while. It was expensive but well worth it! It feels like a new car!
Cheers!
Cheers!
The rubber bushing was worn out, so you are correct in the sense that the strut rod itself (the metal part) did not wear out. According to the Lexus dealer, where the parts were purchased from, you have to buy the whole rod which is about $160 for each rod. I was watching my mechanic reproduce the noise and I watched the wheel/tire move independent/delayed when the brakes were slammed to produce the clunking noise. The gap in the bushing on the strut rod allowed enough play that front wheels continued forward, rather ackward to describe and troubling to actually see it occurr. Hope this help answer your question.
Thanks for the clarification.
That makes sense. From the diagram in the repair manual, it looks like the cushion should be a separate part from the strut bar. It would make things a bit simpler if I can just get the cushion.
Re: Thanks for the clarification.
Unfortuntely, Strut rods have their bushings built in, so you must replace the whole thing. Preferably both at the same time.
The good new is, you can get them for $95 each HERE
Re: Ordered strut rod cushions
I just ordered the strut rod cushions from Carsens Toyota. The link above only shows the strut rod without the cushion. Hopefully, I have ordered the correct part.
If it's not too late, make sure that you ordered the right parts.
I'll call them and double check.
I ordered the strut bar cushions and they said they would have them in on Tuesday. I will call them then and have them check to make sure it is the correct part. So it should be one piece to include both the cushion and the strut bar?
1990 strut rod
Ok, I see from the the above 1997 strut rod, my 1990 strut rod is very different. My strut bar is threaded on one end which goes through the center of the strut cushion. There are bolts that screw on the end of my strut bar on either side of the strut cushion. The strut cushion mounts to the front frame.
My different set of facts re strut rod cushions
Joining in late here (new to this group), but my experience with strut rod cushions was better than all the earlier posts.
My front end man showed me tearing in mine, before I had any complaint.
I called my usual favorite supplier: Champion Toyota in Houston; 800-327-2087.
They immediately offerd me just the cushions, at about $40.00 each. Said they would have to order them; came to me in NC about 8 days later.
My local NAPA machine shop pressed old ones out and new ones in for $10.00; took about 5 minutes. They do have a position requirement, based on a reference rib in the rubber.
Whole job was easy as pie, and ride over bumps is definitely improved.
If the strut rod is allowing lateral play, would this also present problems for the lower suspension arm and specifically that bushing too? My thought is...if you are that far in, might as well get to that one too.
I want to cry !!!!!!!!!!!!!!
I really wnt to cry................
My 96 LS400 had the exact same problem in January. I brought it to a local Lexus dealer to get it fixed and been charged for $1,500.+. I will come to the Club Lexus more often. This is a very expensive lesson.
p1fcl01
RX - 1st Gen (1999-2003)
15
10-03-06 12:31 PM
