Gauge cluster flashes when brakes are pressed
Guest
Posts: n/a
If the brightness adjustor is turned down past the hard click, whenever I push the brakes the gauges turn off for a split second, and if I continue to slow down (longer the brake is held) the gauges turn off.
If I put the brightness switch back to full it stops doing this.
Never heard of that before....
I had the same problem on my '92. It turned out to be a short, in
the rear trunk lid arm. The wire sending signal back to the cluster
for a dead brake light was broken, and causing a problem. Might
want to look at that.
RXRodger
SC- 1st Gen (1992-2000)
05-17-16 07:34 AM
attis
04-15-08 06:53 AM
