Mechanic Says Replace ECU/ECM - HELP!
Old 04-23-04, 09:24 AM
dknoxking
dknoxking's Avatar
Default Mechanic Says Replace ECU/ECM - HELP!
My mechanic says I need to replace my ECU. It is a 93 LS 400. Do I go with a "new" or used?
Old 05-18-04, 12:34 PM
cnacne
cnacne's Avatar
Can you tell us a bit more? Why are you being told to replace the ECU? What symptoms were you having that made you bring the car to the mechanic?
Joe
Old 05-18-04, 12:47 PM
dknoxking
dknoxking's Avatar
I did have the ECU replaced. Car would occasionally not start. Would run very rough when cold. It was odd. My mechanic hooked it up to his computer and could not get a reading. Hope this helps. david
Old 05-21-04, 06:37 AM
Strida
Strida's Avatar
I think you just wasted your money on a replacement ECU. I dont think those problems are ECU related.
Old 05-21-04, 07:15 AM
dknoxking
dknoxking's Avatar
If you say so, but the car runs perfect now!
Old 05-21-04, 08:30 AM
Strida
Strida's Avatar
If it worked, great. But those things could have been related to something else ie. cloged fuel filter, pcv, a much needed tune up? Did the check engine light even came on? But if changing the ECU worked, congrats.
Old 05-21-04, 08:34 AM
dknoxking
dknoxking's Avatar
Thanks! Yes the check engine light did come on. I am glad it worked!
Old 06-17-04, 08:05 PM
LexLS
LexLS's Avatar
So you had a new ECU installed, right? How much did that set you back?
Good to hear it worked .
Old 06-18-04, 07:42 AM
dknoxking
dknoxking's Avatar
It was not cheap..........My mechanic, who is not affiliated with a Lexus Dealership, had to order the part from Lexus. The dealership sent a "remanufactured" ECU, so it was a little less than I originally thought. The part was $918 installed. So far so good!
Old 06-27-04, 09:11 PM
JPI Racing
JPI Racing's Avatar
I'm glad you got it fixed. I hardly see an ECU fail though not on Lexus. What diagnost did he do? I;m just curious.
JPI
bmorekid
11-02-10 08:36 AM
nuocmam122
SC- 1st Gen (1992-2000)
11-26-04 09:45 AM
alexus
05-12-02 10:22 AM
VSsc400
15
05-09-02 07:23 AM
Kajukenbo
04-11-01 08:56 AM
Quick Reply: Mechanic Says Replace ECU/ECM - HELP!
