Polyurethane Rear Swaybar Bushings for under $20
Old 05-13-04 | 09:23 AM
Lexkost's Avatar
Lexkost
persian451 and I will be doing some mods on his 91LS,I will then be able to get some measurments off of his car for the bushings, so I will keep you all informed.
Old 05-13-04 | 10:00 AM
Pagong's Avatar
Pagong
i want a set...where do I sign up?
Old 05-13-04 | 10:55 AM
persian451's Avatar
persian451
Originally posted by xmystikx
Lexkost!! sign me up too! OH AND I WANT TO GET SOME STRUT BAR WASHERS OFF YOU. i hear you sell them so could you pleeeeaaassee email me and give me some info and how i can purchase off you? "allenchu2486@yahoo.com"
dude how old are you, you sound like a kid begging for candy
its all good
Old 05-13-04 | 11:05 AM
retrodrive's Avatar
retrodrive
Search Function Inc.
Guys, see if you can fit a '94 tie bar on there. I can probably get you one from local junk yard for testing putposes. Why is it so important? Tom's has a whole set of aftermarket tiebars that would fit 94+ LS but not the lower years.
Old 05-13-04 | 11:14 AM
Lexkost's Avatar
Lexkost
retro, Get the bar from a junkyard and we can get it to work.
Old 05-13-04 | 04:11 PM
LeXuSrAcIn's Avatar
LeXuSrAcIn
I want the washers too as well as the bushings, but you havent PMed me back yet.
Old 05-14-04 | 06:57 AM
Lvangundy
Guest
Posts: n/a
RETRO -
1994 Celsior would be the 1995-1997 models here.
Different suspension on those models.
Old 05-14-04 | 06:28 PM
retrodrive's Avatar
retrodrive
I just picked up a '95 sway bar from junk yard. Peter, let me know when you are going to see Mike!
Old 05-14-04 | 07:09 PM
Lexkost's Avatar
Lexkost
Retro,Did you get the end links with the bar and is it thicker than the first gen?
Old 05-14-04 | 07:25 PM
retrodrive's Avatar
retrodrive
no, I did not get the end links but I can pick them up tomorrow if we need them. I can't tell you if it is thicker or not, I don't have my car.
Old 05-14-04 | 10:25 PM
persian451's Avatar
persian451
i'm probably going next sat... 5/22
Old 05-14-04 | 11:31 PM
Lexkost's Avatar
Lexkost
I don't think you will need the endlinks, but if they are free get them.
Old 05-17-04 | 10:43 AM
Lexkost's Avatar
Lexkost
Install for bushings on my 96LS the swaybar dia. is 1 1/16 and there is a mod needed to fit the new bushing on, notice the length.
Attached Thumbnails Polyurethane Rear Swaybar Bushings for under -my-pictures0002.jpg
Old 05-17-04 | 10:46 AM
Lexkost's Avatar
Lexkost
The new bushing mount must be bent both ends up a 1/2" to fit frame of car:
And then you can install back on car withstock bolts and a 5/16 flat washers.
Note remove and install this with car on ground and wheel turned to get access from in front of the wheel.
Attached Thumbnails Polyurethane Rear Swaybar Bushings for under -my-pictures0006.jpg
Old 05-17-04 | 11:05 AM
Lexkost's Avatar
Lexkost
This is a pic of inside of the old bushing note the crack and shiney spots ..........This is the bushing that make the creaking sound on all LS cars once you install these new bushings and grease them it will be gone!
Attached Thumbnails Polyurethane Rear Swaybar Bushings for under -my-pictures0003.jpg
Quick Reply: Polyurethane Rear Swaybar Bushings for under $20
