91 Lexus on 20's...needs a lift
Old 06-13-04, 08:34 AM
Sbelangia
Sbelangia's Avatar
Default 91 Lexus on 20's...needs a lift
SO I just finished painting my 91 Lexus LS400. It took me 150 hours total counting pulling the front of the motor down, fixing the camshaft leak and timing, and painting everything-----inside the motor compartment and all the jambs... I painted it a light green with a heavy yellow flop and add about 8 oz of metal flake. After I painted it I had to re-clear the whole car to cover the coarse flake... I had the doors off and everything tore down completely---I have plenty of pics. My only problem, I put a set of 20" spinning wire wheels on it and now it's lighlty scrubbing the wheel wells--- I've seen LS400 with 20's before..wondering if anyone knows a good way to raise it slightly--- Ihave a set of coil spring boosters in it now but I need something a little better.... anyways, any help is appreciated....Hope you like it
Old 06-13-04, 10:30 AM
sniper
sniper's Avatar
raising the car wouldnt be a good idea, it would look really bad. What you need to do is run a thiner tire. What size tire is on there right now?
Old 06-13-04, 10:31 AM
persian451
persian451's Avatar
Does it glow in the dark?
Old 06-13-04, 10:42 AM
johnee78
johnee78's Avatar
Exclamation
It looks like he is running a 255/35/20...He should go down to a 245/35/20 and maybe most of the rubbing problems will go away...
Old 06-13-04, 12:44 PM
Pagong
Pagong's Avatar
why dont you flare the wheel wells a bit to accomodate the rims you have on. Raising the car up would make it look ugly.
but yeah, different strokes for different folks..but this definitely isnt my cup of tea. Good Luck with your lowrider.
Old 06-13-04, 01:25 PM
sniper
sniper's Avatar
Im lookin at it again and looks like your offset is not right, whats the offset of those rims? doesnt look like they will fit.
Old 06-13-04, 02:44 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
Just for info. There are wires running above the fender well, once you rub through plastic and get to wires you will have all kinds of electrical problems. Make sure that does not happen. Happened to me before.
Old 06-14-04, 03:11 AM
Sbelangia
Sbelangia's Avatar
SO I do have 255/35.... wish I had gotten the 245 instead.... I'm not really planning on raising it as much as trying to get it to bottom out before it hits the tire. I got wires with a high postive offset so they wouldn't hit the brake caliper but I needed them kinda deep so Icould put on the spinning kit. Kinda looking someone else with 20's to see if they have the same prob. I had to take out the fender lining and windshield washer resivoir to get them on.... Thanks everyone for responding so far.....
Old 06-14-04, 03:14 AM
persian451
persian451's Avatar
I believe the correct tire size without wheel spacers would be 245/40
Old 06-14-04, 10:55 AM
nk1983
nk1983's Avatar
Lightbulb
I got a name for your car. The grinch that stole lexus..
the body work looks good....ummm
yea run 245/35 and it wont rub. PUT the lining back asap theres a reason its there!
Old 06-14-04, 12:55 PM
Wide LS
Wide LS's Avatar
Are you rubbing on the front or back? I had problems in the back so I bought these rubber things you put on your spring that makes your springs stiffer therefore raising the car 1/2 or if you buy them bigger they could raise it 2 inches. They cost like $6 at an auto part store. Just tell them you want to raise the car slightly and you want the rubbber thingys. I forgot what they are called but I think it's the best way and cheap too.
Old 06-14-04, 01:02 PM
ATSOU
ATSOU's Avatar
The offsets on those WHEELS are wrong that's why!!!
Old 06-14-04, 01:55 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
I'm not sure if you were planning on going for the lowrider look with the wheels sticking 2-4 inches out of the fenders, but your wheel offsets are definitely way off...and that's the main cause of your rubbing issues.
Old 06-14-04, 05:48 PM
LexFather
Guest
Posts: n/a
I think the look you want looks better on an Impala or Caprice, not a Lexus.
No one EVER wants to raise their cars. We want to LOWER our cars. If you have to raise it, that is the usual common sense indication something won't fit right and it sure won't look right unless you use expensive modifications.
You probably did not buy the rims for the LS. They are rims from another car and you think you can just slap em on and they will fit. Shoot at this rate I hope the lug pattern is correct.
Old 06-14-04, 06:22 PM
RA40
Super Moderator
RA40's Avatar
Saw a first gen at Lakewood the other day with 20" Giovanna (sp?) with a similar wheel layout. Short of flaring the wells, I dunno if going down 10mm in tire width is going to be sufficient to clear. Like the others stated, lowering will finish the look off.
Congrats on putting your heart and soul into your car...it is an enjoyable effort to see what was once in your head a reality.
Quick Reply: 91 Lexus on 20's...needs a lift
