Help: Inner Tie Rod Removal Tool
Could someone tell me the cowfoot tool size to removal the inner tie rod? Does
anyone has the procedure from the service manual? The information below is
from Lexus/Toyota steering housing overhaul tool set. I know one of the tools
is a 34 mm crowfoot wrench.
09612-24014 STEERING HOUSING OVERHAUL TOOL SET
09616-10010- STEERING PINION BEARING ADJUSTING SOCKET
09616-10020- STEERING PINION BEARING ADJUSTING SCREW WRENCH
09617-22030-01- STEERING RACK END WRENCH
09617-22040- STEERING PINION BEARING ADJUSTING SCREW LOCKNUT
WRENCH
09617-24011- STEERING RACK WRENCH
09617-24020- STEERING PINION BEARING SCREW LOCKNUT WRENCH
09617-24030- STEERING RACK END WRENCH (34MM)
09612-10022- HEXAGON WRENCH
09612-10050- STEERING RACK SHAFT BUSHING REPLACER
09612-10061- STEERING PINION BEARING REPLACER
09612-24022- CASE
09613-22011- PULLER
I know I need to buy the service manuals.
WRENCH
09612-24022- CASE
09613-22011- PULLER
