anyone need to stop the smoking on start up?
Old 07-08-04, 12:43 PM
blkstealthpaid4
blkstealthpaid4's Avatar
Default anyone need to stop the smoking on start up?
I have a couple of used Idle up valves for the first gen LS
Old 07-08-04, 04:20 PM
tvd51
tvd51's Avatar
I have smoke problem at startup. The problem is much worse if I use regular oil and a lot less with synthetic oil.
Could you tell me where that idleup valve is? I can't even find it in the manual.
Thanks,
tvd51
Old 07-08-04, 06:54 PM
blkstealthpaid4
Default I have the idle up valve
This is located on your power sterring pump.I have them for $70 bucks.This is just the valve without the power steering pump.I only do COD.I have shipped this part out to a few members online like "retrodrive" etc...
Old 07-09-04, 09:32 AM
tvd51
tvd51's Avatar
I talked to my local Lexus dealer and they don't know anything about this valve. I told them what I've read on this forum and they wonder if American version of Lexus is different from the Canadian one.
As long as I understand, a faulty idle up valve causes steering fluid leaking to the combustion chamber and it makes smoke at start up. Is that correct?
My smoking problem only occurs after the car sitting for several hours (overnight and afterwork).
Thanks,
tvd51
Old 07-09-04, 11:34 AM
CUMan
CUMan's Avatar
The Toyota-Lexus name for this part is the air control valve. It screws into the bottom of the power steering pump. It has two hoses which run from the valve to (1) the air intake system just downstream from the air filter and (2) the front of the intake manifold. When the valve fails, power steering fluid is drawn into one or both of these hoses and makes a cloud of white smoke when the engine is cranked.
Anyone suspecting that this valve is faulty should check their power steering fluid level often.
This is a very common problem on first generation LS models.
Old 11-04-11, 07:57 AM
08lexus350
08lexus350's Avatar
i have a 08 is350, seems like its the same problem as i have now. but my power steering is electronic, i still haven't figured out whats could be wrong
Old 11-04-11, 12:56 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
it's not related. totally different setup.
Bakewalk
IS F (2008-2014)
07-11-18 05:53 PM
JohnEd
Performance & Maintenance
12
11-03-08 04:31 PM
POS
06-05-04 08:47 PM
chliansh
07-02-03 03:45 PM
Quick Reply: anyone need to stop the smoking on start up?
