91 LS Ac Blows Cold on 1 side & Hot on the other?? What could be the problem?? Help
Old 07-15-04, 09:00 PM
DroppedGS
DroppedGS's Avatar
Angry 91 LS Ac Blows Cold on 1 side & Hot on the other?? What could be the problem?? Help
I have a 91 Lexus LS 400. I went to get my AC charged today because my car have been sitting for a while before I brought it, and it was low on freon.
At first my car would just blow hot air on all sides.. Now my car only blows cold air through the front right
Vent. All the other vents blow Hot Air.? What could be the problem my car is fully charged.
Ps.. He also checked to see if my car has any leaks, and he said the car doesn't have any leaks. What should I check for? What could he have done wrong?
Old 07-15-04, 09:09 PM
nthach
nthach's Avatar
i would check the mix/mode door in the HVAC unit, it could be stuck.
Old 07-16-04, 04:31 AM
DroppedGS
DroppedGS's Avatar
What do you think I should do to fix this problem?
Old 07-18-04, 06:09 PM
DroppedGS
DroppedGS's Avatar
anybody?
Old 07-18-04, 09:49 PM
nthach
nthach's Avatar
check the mix and mode door solenoids, if does require you to pull the HVAC unit...
cutecboy
02-09-08 09:14 AM
98LexusGS
Maintenance
06-20-05 12:38 PM
LeXuSrAcIn
05-12-05 09:34 AM
jemelb
Southeast
09-22-04 07:02 PM
meZoom!
03-31-03 11:09 AM
Quick Reply: 91 LS Ac Blows Cold on 1 side & Hot on the other?? What could be the problem?? Help
