Addco rear ant-roll bar
Old 11-18-08, 05:06 PM
  #61
hobojoe
hobojoe's Avatar
UPDATE: for all that are interested in this. I have had the Bar for about a month now. The end holes on the bar were too small to fit the stock end links so you have to drill them out to get the threaded studs to fit in.
FYI to loosen the nut theres an allen on the end of the stud that you must hold!
Anyways when i ordered the bar i got brackets that were no where near the same as the old oem ones. I called addcco about it and they obliged me with no fuss at all. They sent me new deeper and skinnier brackets with new poly bushings to fit also. these are very very close the the same as the oem ones and fit almost perfectly.
The one thing you will have to do it buy 4 new longer 30mm bolts with washers and lock washers to replace the old ones as they dont have washers, and are not long enough to thread very far into the holes. I also reccomend using a little bit of loc-tite to hold them on better.
It has been 3 weeks with this all doen i have no odd sounds or rubbing of anysort, and the bar works AMAZING! I highly reccomend it to anyone looking to improve there handling.
Old 11-19-08, 07:25 AM
  #62
steveski
steveski's Avatar
Great write up Brother! Sounds like you had to do all the same things I did. It was way more work that it should have been but in the end for the money it was worth it
Old 11-19-08, 10:44 AM
  #63
PureDrifter
BahHumBug
PureDrifter's Avatar
heh, i'm ordering this after christmas
Old 11-19-08, 12:02 PM
  #64
Lexkost
Lexkost's Avatar
Pure, let me know where you get yours and we can get two and do both at my home and take some pics to show what needs to be altered , for the guys.
Get a good price on 2 and I will pay for them and you repay me later ...let's do it over Xmas vacation............. I will be off from work.
Old 11-19-08, 12:19 PM
  #65
ryanSC300lover
ryanSC300lover's Avatar
That's a deal. Mike, will you pay for mine, as well?
Old 11-19-08, 02:14 PM
  #66
PureDrifter
BahHumBug
im down, i'll be in for it over xmas break.
i needa pull a few extra hours this month to finance this
Old 11-19-08, 02:15 PM
  #67
ryanSC300lover
24-29 I will be in LA (few minutes from Mike's house) if you guys do it then.
Old 11-19-08, 05:07 PM
  #68
hobojoe
hobojoe's Avatar
Haha good luck all. I bought mine from summit racing and it was a special order so dont plan on a fast delievry if you go there as it took 2 weeks for mine to get to me. I will also try to post some pics of the Correct bracket versus the wrong one. Feel free to ask any questions you have.
Old 11-20-08, 11:14 AM
  #69
steveski
steveski's Avatar
Great idea - I should have done this when I installed mine Maybe ADDCO has fixed these issues (lol). I contacted them to share feedback but no dice.
The only thing I think that could be better is if there were heavy duty type end links. Since mine has worked fine for a long time I guess it is not necessary.
Old 11-20-08, 04:42 PM
  #70
hobojoe
hobojoe's Avatar
Steve:
It took some doing but they do make replacement endlinks that are 'A LITTLE" beefed up i found them after searching for a while they look the same as oem but are gold and the center rod is just a little thicker.
As for other options they do make others but none are a direct fit mods will most defiently be required.
KINETICS
Suspension and Brakes
20
07-15-20 08:45 PM
bacardi11
04-19-19 03:08 PM
fbg
NX - 1st Gen (2015-2021)
04-07-19 06:51 PM
MCV20
69
08-23-06 12:16 PM
GS400kid
03-10-03 09:09 AM
Quick Reply: Addco rear ant-roll bar
