Addco rear ant-roll bar
The rear anti-sway bar for the UCF-20 will be available as of next week. This is a super low run as 10 bars are stated to be produced. The size will be 7/8" compared to the 9/16" of the stock bar. The chart I have indicates this 7/8" bar will be about 315% stiffer than the stock bar.
If you wish to order this, give Todd at TM Engineering a call:
310-537-6800 Addco part# 2027
just put in an order for my ls400 1990', i 170$ to door dunno how long the waits going to be aka if its made yet or not, its also addco brand, 7/8 of an inch thickness dunno what stock is but im sure its much smaller
ill give an update once i get it and put it on
lspower, I just worked on persian451 1gen LS and they come stock with a 3/4 inch bar and is a different set-up than the 2nd gen................Let us know how the new one works.................Thanks MIKE
Originally posted by RA40
The bar arrived today with a zinc finish. I dunno my schedule but I hope to install it later this week. The box included the bar and two new bushings...based on their instructions, I use the existing hardware so I hope it is straight forward.
Thanks for the tip Mike. I haven't been under there to look at it yet. Todd had removed the nut on the end links when he installed the rear struts...it shouldn't be to hard to loosen it now. (I hope.)
Need some good tires...as it is now, the touring Michelins are
The sway bar will improve handling but the tires won't tolerate it. I had the back-end get loose and it was
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
You can see the difference between the stock and Addco. I think the stock bar is hollow as it weighs approximately 6 pounds. The Addco is at least 20 or so.
Unfortunately my abdominal injury still nags me so this was a painful attempt.![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I crawled under the car and it looked simple. Har-har. The stock bar is easily removed however, the upgrade was not so nice going back in. The simpler bend does not lend itself to snaking through the exhaust and clearing other undercarriage obstructions.
The easiest way I think...is to remove both rear mufflers so that it simply bolts right up. Maybe just removing one will do also. I ran out of time as the Mrs. needed the car. I had the stock one in-out in about 20 minutes though.
17mm for the end link nuts and 12mm for the bushing clamps. 6 bolts total.
Frustrating to be so close and not get it all done.
![Bang Head](https://www.clublexus.com/forums/images/smilies/banghead.gif)
i looked at ur pics then under my car at the sway bar and the one under my car is exactly the same as the addco just not as thick. ill give an update when its on this week
its on and running almost perfect NO rubbing issues except i need some new end links, the bar is amazing though. it fits like a glove, just those end links for the bar and ill be set, highly reccomended, ride quality has not decined at all but ride feeling/handling is much improved
