View Poll Results: Which would you choose?
98-00 LS400 Headlights
13
37.14%
01-03 LS430 Headlights
8.57%
04 Headlights
19
54.29%
Voters: 35. You may not vote on this poll
Which headlight is better?
Thanks, I agree. I really like the design of the 04 lights but they might not match as well and i might need to change even more things. That would equal, EXPENSIVE. Thanks again for the reply
I agree with j three's opinion. I also have a little something more to add...just thought I should give you a 'lil more to think about before you make a decision...some pros and cons. Yes, the '98-'00 would flow better with your '94 and probably will be a 'lil less expensive to do than the '04 , but won't give you as good of a light pattern/output as the '04. The '04 on the other hand, will be more costly (depending on if you opt to go with a complete '04 swap...hood/fenders/bumper), but will give you better lighting IMO since it uses projectors instead of reflectors like the '98-'00...just my two cents.
A3OD
HS 250h Model (2010-2012)
04-20-19 02:26 PM
