retrofit to 134a: need to drain old oil?
re: flammability on R12a?? Really guys, are you scared about this. Gasoline is a much much more flamable material !!!!!!!
Yes, EPA doesn't like it---can you really tell me why they care if I live or die--they worry about the enviroment --not me!!!! They don't like it because they can't control it !!!
Also, you can't mix it with the controlled stuff, because it can't be sold again for a profit when the a/c shop sends it back for monentary credit. That is what the epa doesn't like.
BUT, I will continue to go over the speed limit, use outlawed headlights,use R12a, also download copyrighted CD's, and I could list many many things but I would be wasting my time for the conformists.
Also reminds me of those that refuse to buy a Toyota Prius because Emer. Response Teams refuse to cut into it after a wreck because it has about 500 lethal volts in it. { and if you don't know what I am talking about, then you are not up to date.}
Are you all aware that anything but sealed beam headlights were outlawed by the DOT for years and years after they were used in Europe; then someone told them they were better--now only antique cars use seal beams !!!!!!!!!!!!!!!!!!!!
134a, change, charge, drain, dryer, envirosafe, ester, flush, forums, gs300, installing, interdynamics, oil, r12a, r134
