1st gen. LS400 Exhaust
I was wondering if anyone knew how to take off the original exhaust tips on a 1990-1994 Lexus LS400. I just bought some nice new black chrome exhaust tips to match my black pearl emblems, but I don't know how to take off the stock exhaust tips. Does anyone know how? Any help would be GREATLY appreciated. Thanks Again
-John
-John
Originally posted by persian451
you cut them off and weld or clamp on the new ones
I don't think screwing it on is going to hold. You're better off welding the tips on. That is a particullarly easy job to do. You shouldn't pay more than $100 bucks for it. Make sure they weld it straight though, cus crooked tips will look nasty. Post some pics when finished
-John
there are four 10mm nuts(total) that hold both rear pipes and resonators to the other pipes[these are the flanges--take these off to check the tip closer if you need to.
on the orig tips, you have to rotate about 5 degrees so as to clear the spring connectors on the tips from the welded sholders on the pipes then pull off.
on new ones; install with pipes on car so as to be straight, tack if you want to, then remove for final stuff.
corkycal
10-04-04 04:02 PM
