Fixing a 1990-1992 LS Instrument Cluster
From end to end it's about 3 1/8", this includes the cover. I took the needle all the way off and it measures about 2 11/16". I broke off the black section towards the end of the needle, it has a resistance of roughly 1100 ohms. My guess is that the total resistance that joins the ends of the cathode is about 2000 ohms. Does this make any sense?
Originally posted by nthach
is there a mirror behind the gauge faces to give the warning lamps the projected look?
My odometer gauge is also wrong...only half works and my fuel gauge works and moves a little bit slowly. When I fill up my tank my gauge won't even go on the top...(4/5 tank). So this must be every LS problem...\
LS400 1990
LS400 1990
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
1990 LS400 no problem with the board
LS400 1990
LS400 1990
On a different note, I may have a few possible options for fixing the needles. I'm not sure I want to invest more of my money into this to try them out though. I've already invested a lot of my time and money with no return.
Before I had my 93 LS dash display repaired by Jim Walker in November, 2003, I had the usual problem of the display not lighting up when the weather was cool. I noted then that the odometer does not add miles when the display is not illuminated. I did not have any other problems involving the mileage counter.
Originally Posted by jcolegrove
hi,
can we get back to if anyone has figured out or heard from jim what the conductive wire/coating is on the needles? i can get VERY fine wire, if needed....
JC
JC
1990 LS here and so far *knock on wood* only the temp. needle acts up. It takes awhile for it to light up.
If OLT can do the LS gauges to accept his "waterfall" look I will be all over it
so i pulled my panel completly apart and tried to figure out what the coating was...i had no idea, but it looked alot like electrical tape...haha, so i tried tape...no cigar
what the heck is that stuff!? its blowing my mind
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
