Where to Buy Ball Joints? quick question
Old 09-19-04, 06:04 PM
GSX1300R
GSX1300R's Avatar
Default Where to Buy Ball Joints? quick question
I need the ball joints replaced the front right side of my 1990 LS400. I searched through the forums and couldn't find reliable answers.
A) Do the ball joints press in, or does the entire arm have to be replaced?
B) If they can be pressed in and out, are they the same on the left side as on the right?
C) I can't find anyone selling either the arms or ball joints!
Patrick
Old 09-20-04, 02:19 AM
brit_lex
brit_lex's Avatar
You don't need to press them in. You can buy them separately from the arms. I bought mine from www.olyonline.com
Not OEM, but pretty good and cheap too.
Old 09-30-04, 02:46 PM
hlovepenn
hlovepenn's Avatar
I recently changed out the lower ball joints on my 1991 LS400--easier than it looks. You need a pickle fork to seperate the balljoints from the control arm, but that's the only hard looking part. Got mine from NAPA Auto Parts--they ordered them and had them the next morning. Also, take a look at the Daizen bushings for your car. I recently traded for a 1996 and they're not available for gen 2 yet. Good luck!
Old 09-30-04, 07:51 PM
junfei
junfei's Avatar
Does this apply to all the ball joints? specifically the front and rear upper ball joints?
Thanks
Old 09-30-04, 09:20 PM
hlovepenn
hlovepenn's Avatar
Since we replaced the lower ball joints, I checked my Chiltons and they state that the upper ball joints are integral with the control arm, so you need to replace the whole unit. As for the rear upper bushings, they can be replaced without replacing the control arm. I suggest going by Half-price books and picking up a 89-93 import car manual by Chilton or find one on Ebay--they won't cost much--might even find one at Goodwill or Salvation Army! Thanks for the note and I hope it helps. One thing--be careful! Let me know if you have any other questions.
Howard
Old 10-01-04, 08:47 PM
junfei
junfei's Avatar
Howard
Thanks for the confirmation on the ball joints, but the bushings in question are the rear LOWER bushings attached to the knuckle and what seems to be a "track rod".... I don't know whether that is the correct terminology for that piece, but the bushing is fairly worn because you can see the rubber bushing flex tremendously while wiggling the track rod. The car doesn't seem to have that smooth ride that everyone is praising.... I've just purchased brand new tires to be installed, and will be replacing the worn suspension pieces along with an alignment and hope to restore the ride very soon
thanks again.
Old 10-02-04, 08:09 AM
hlovepenn
hlovepenn's Avatar
Check ou the Daizen bushings for both the front and rear. The other posts seem real complimentary on them and I think they are supposed to last a lot longer than the stock bushings! Good luck.
1jzchris
SC- 1st Gen (1992-2000)
07-02-11 08:29 AM
O1GS43O
Suspension and Brakes
06-01-10 08:34 PM
frankjames
07-20-09 09:51 AM
n737nc
02-06-07 05:42 PM
junfei
10-01-04 08:53 PM
Quick Reply: Where to Buy Ball Joints? quick question
