A/C hose replacement?
Old 10-05-04, 03:04 PM
ls400dude
ls400dude's Avatar
Default A/C hose replacement?
My A/C died, and my mechanic says that the a/c hose behind the driver's side headlamp is leaking.
He told me $380-400 to replace it. Holy Cow!!! hose replacement is $400?
Does this sound right? or is this something I an DIY?
Please, I need some more info, and help... with this 91 LS400. I am frying in this thing...
Dan
Old 10-05-04, 05:52 PM
Lextreme
Lextreme's Avatar
When i install my turbo, i cut them out thinking they would be on the way, but they not. Anyway, got a used set from ebay for 45 shipped... try to email those guys parting out a LS. Email them and ask for that part..
good luck
Yes, its a DIY... perhaps i can do a tutorial on this topic...
david
Old 10-05-04, 10:22 PM
nthach
nthach's Avatar
Default Re: A/C hose replacement?
Dan
Go find a AC shop that custom-fabs hoses. Should be lots cheaper. You can replace, but it's quite easy to bend the metal line that runs between that hose and the condenser.
Old 10-06-04, 08:05 AM
ls400dude
ls400dude's Avatar
Default typical problem?
Thanks for replay guys, you gave me some things to try.
David, Yes, a detailed tutorial instruction will give me better idea as to what is involved.
Is this typical of 91 LS400 model? I know of couple more guys that had A/C problem on their Lexus...
Dan
Old 10-06-04, 11:00 AM
nthach
nthach's Avatar
Default Re: typical problem?
Dan
The Denso 10PA20C compressor isn't the greatest thing in terms of reliabilty, IMO Asian car makers under fill the system with oil. When I retrofitted my car, I used 8oz of PAG 100 oil instaed of the usual 6 oz.
My car had 5 compressor replacements, I found out with a VMI.
Old 10-07-04, 10:10 AM
hyperopt
hyperopt's Avatar
No need to buy new or custom hoses. Take the existing hoses to a local competent AC shop and tell them you want to replace (rebuild) the rubber hose. They will remove the hose with its couplers and insert a new hose with new couplers and dweld the new section back replacing the removed section - common procedure for AC shops. The results are as good as new with original fittings and curvatures. Rebuild both hi and low pressure hoses while you're at it.
Old 10-07-04, 11:22 AM
ls400dude
ls400dude's Avatar
Default any shop recommendation?
hyperopt;
Thanks a lot, that's another good suggestion. Did you have to take the hose off to bring it to them? or did they take it off your car for you? How much do they generally charge?
Also, I live in SoCal, do you have a AC shop that you trust?
Please advise.
Dan
Old 10-07-04, 11:38 AM
Lextreme
Lextreme's Avatar
Email me lextreme@lextreme.com .. i know few places does hoses while you wait in socal. However, i know a great place does very custom aerospace fittings..
Old 10-08-04, 09:48 AM
hyperopt
hyperopt's Avatar
I always remove the hoses and take them to the shop. That way, I can thouroughly inspect their work and not having to pay extras for labor. It costed ~$100 to rebuild both high and low on my LS.
Old 10-08-04, 11:39 AM
ls400dude
ls400dude's Avatar
Default How hard to do?
Hyperopt;
Thanks for your advise, couple more questions...
How hard to take off the hose from the condenser behind the driver side headlight? I don't know whether this is hi-side or lo-side...
How hard to take off the other side?
I've never tried to take them off, so I have no idea...
Where do you take yours to rebuild?
Please advise.
Dan
Old 10-08-04, 11:50 AM
Lextreme
Lextreme's Avatar
Dan,
I assume u still have some feon in there. Wear those heavy duty gloves and some protective gear like glasses. Loosen the screw one at a time and very slowly. Release it little and wait for a while... then more.
Old 10-09-04, 08:49 PM
ls400dude
ls400dude's Avatar
Default No freon
I wouldn't be asking if I had freon.
When it was charged, it took 3-4 days for it to escape... My mechanic told me it was leaking at the hose connector...
No freon in there...
How hard is it to get to thise hose and take it out?
Old 10-11-04, 03:30 PM
hyperopt
hyperopt's Avatar
I don't recall having any problems removing those hoses.
Are you anywhere near Brea Mall?
Old 10-12-04, 08:11 AM
ls400dude
ls400dude's Avatar
Default yes
Hyperopt;
Glad to hear that it's easy replacement for those AC hoses...
I live about 5 miles from the Brea Mall. Why?
OldLs400
03-11-19 07:59 PM
SlavicLS
05-10-17 03:12 PM
RawkusX187
SC400 / 300 Classifieds
05-18-10 08:45 PM
MarcusMIA
Performance & Maintenance
03-29-10 01:57 PM
Herm
Maintenance
01-15-03 10:07 PM
Quick Reply: A/C hose replacement?
