Are the 2nd Gen LS400 (95-97) as reliable as the 1st Gen LS400s (90-94)?
Old 11-12-04, 10:13 AM
DroppedGS
DroppedGS's Avatar
Default Are the 2nd Gen LS400 (95-97) as reliable as the 1st Gen LS400s (90-94)?
I have a 1991 LS400 with 90k. I have been thinking about selling it. I would like to know if I were to buy a 95-97 LS400 with around 80-90k will I have the same or better reliablity as my 91. What tends to go bad on the 2nd Gen?
Old 11-13-04, 08:51 AM
SharpLS-96
SharpLS-96's Avatar
Default Re: Are the 2nd Gen LS400 (95-97) as reliable as the 1st Gen LS400s (90-94)?
They are just as reliable if not more but try stick with either a 96 or 97 since a 95 seems to be prone to more problems and isn't OBDII compatable.
As far as what tends to go bad, the normal things such as most bushings, struts etc. Most normal wear and tear items.
Old 11-13-04, 08:58 AM
DroppedGS
DroppedGS's Avatar
Default Re: Re: Are the 2nd Gen LS400 (95-97) as reliable as the 1st Gen LS400s (90-94)?
Thanks for the reply! What is the difference between OBDI & OBDII??
Old 11-13-04, 09:09 AM
SharpLS-96
SharpLS-96's Avatar
Default Re: Re: Re: Are the 2nd Gen LS400 (95-97) as reliable as the 1st Gen LS400s (90-94)?
Basically, the difference is in the amount of smog equipment and sensors the ecu "looks" at for input. An OBD II is self correcting to improve emissions after driving. It constantly remaps it's own fuel curve based on sensor readings to minimize emissions based on driver input. Not to mention, it's also easier to diagnose a problem if or when there is one with the car.
Old 11-13-04, 09:50 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
But you'll miss that V8
Old 01-25-06, 11:19 PM
JDMUSCLE
JDMUSCLE's Avatar
wow...talk about miss leading someone....95 ls400 is obdII also....who told you that they were obdi?/
Old 01-26-06, 05:54 AM
sha4000
sha4000's Avatar
i guess he was just assuming b/c most car companiesdidnt make cars obd2 until 96 when it became the law but lexus made all their cars obd2 in 95
Old 01-26-06, 06:22 AM
ychachad
ychachad's Avatar
Sorry
The Gen 2 1995 LS400 is very much OBD II compliant. Lexus was 1 year ahead of the game.
95 is equally reliable as a 96 or 97.
OBD is NOT self correcting - it is simply a diagnostic tool.
Old 01-26-06, 06:54 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
yeah, my '95 is OBDII all the way
Old 01-26-06, 08:17 AM
caffeine
caffeine's Avatar
I have a 95 LS400 that I bought a little over a year ago with 99k miles. I've put on like 15,000 miles since and they only problems I've had were minor.
1. Had to refill the A/C freon. ($60 to refill)
2. Pinhole leak in my powersteering fluid (I just remember to top it off every 2-3months)
3. Driver's side power door lock stopped working. ($500 to replace, dealer only part...so I'm just using my key now instead of the remote)
4. Heated seats never worked.
5. Lowbeam bulb went out. ($10)
Umm, that's it. But then again I did do a full major service on the car when I first bought it, including changing the sparkplugs, wires, waterpump, belt, and a host of other things that cost me $1,300. But all that was more preventative maintance, which I could have waited another year or two to have done. Over all I have been very satisified with the reliablity of my 95' LS400.
dicer
18
07-18-15 10:48 AM
rebith75
18
03-20-09 07:23 PM
saustin
06-23-05 06:08 AM
Quick Reply: Are the 2nd Gen LS400 (95-97) as reliable as the 1st Gen LS400s (90-94)?
