Emergency Help & opinions needed!!
Just had an odd occurence in my 94LS. Seems to be intermittent & electrical in nature.
My vehicle temporarily lost all electrical power while driving!
The engine died. Sometimes it would temporarily re-start & not idle others times nothing.
Hazard lights would not even flash for a time.
Was getting ready to call AAA , when I re-started & made a trouble free , no symptoms drive home.
What is going on here??
I need help!! damon
I need help!! damon
From searching here is:
I have the dreaded PS fluid leak onto the alternator.
If these are the initial signs of this, how much damage have I done to my alternator?
The service tech I just called said the battery light will come on but it may not depending on the circumstance. I dunno if this is the same for the LS, on my other Toyota, when the alternator failed, I got a brake, check eng and battery warning lights. The battery will power the car for a short time before it drains.
Get it in...you don't want to be stranded!
Battery is brand new & in great condition.
It is possible that the Positive & Negative battery cables may need further investigation & perhaps replacement. Ground wire as well!! Thanks RA.
Went on a parts ordering spree today. All things that I would do when I do my timing belt anyway.
My List:
OEM Lexus
Front Alternator Bearing 90099-10182
Rear Alternator Bearing 90099-10194
Brush & Holder 27370-75060
PS Pump Seal Kit 04446-30173
Power steering pressure hose:
Had a spare one repaired at Hose-Fast : $54.13
Dayco Parts / w Dayco part #'s
Timing Belt 95190
Serpentine Belt 5060885
Tensioner 89255
Pulley 89026
Radiator Hose ( Lower ) 71538
Radiator Upper Hose 81161 NA
Total: $254.33
All above except the Upper Rad. Hose
My List:
OEM Lexus
Timing Belt 95190
Tensioner 89255
Pulley 89026
Total: $254.33
