Does 91 Lexus LS400 have a Starter Kill in factory alarm? Help Please Car won't Start
Old 11-18-04, 07:25 AM
DroppedGS
DroppedGS's Avatar
Default Does 91 Lexus LS400 have a Starter Kill in factory alarm? Help Please Car won't Start
I would like to know does a 91 Lexus LS400 have a starter kill in its alarm system? Because I was testing my alarm to see if it still worked with this new door I put on ( my car was in an accident) and the alarm went off when I opened the lock through the window. When I went to put the key in the ignition the alarm turned off, but now the car won't start.It doesn't even try to start, you just hear a tick sound when I turn the key. Also now my trunk opener and my power locks switch doesn't work??
Ps.. I don't have a key for my Drivers door as of yet because I just installed a new door and it have a different lock.. I wasn't able to put the lock from my existing door because it was all smashed up and I couldn't use it. I was wondering do you have to unlock the driver door to disarm the alarm? Does this car have a start kill??
Old 11-18-04, 12:15 PM
stuart browne
stuart browne's Avatar
Yes it electrically disconnects the starter, your trunk will not open nor your doors.To reset do following open doors with remote door lock control, or open passenger side with key. Unlock your trunk with key and open trunk, the theft system will be reset. When you have done this turn the theft system off untill you get drivers door lock key.
bigunit (10-09-22)
Old 11-18-04, 07:35 PM
DroppedGS
DroppedGS's Avatar
Thanks Alot! It works now.
Old 12-16-04, 08:53 AM
NC211
NC211's Avatar
How do you turn the theft system on and off? My alarm doesn't work. It beeps when I hit the buttons to lock and unlock, but the panic botton doesn't work, and I open the door like Dropped can, but the alarm won't go off. Am I missing a switch somewhere? Mine is a 95 LS
Thanks
Old 12-17-04, 01:14 PM
nagasakki
nagasakki's Avatar
is there a volume control for alarm set on? if you look underneath the driver's vent on the left. it might be there. well try it if it works.
Old 01-09-15, 08:25 PM
diegojr
diegojr's Avatar
[QUOTE=DroppedGS;1104043]I would like to know does a 91 Lexus LS400 have a starter kill in its alarm system? Because I was testing my alarm to see if it still worked with this new door I put on ( my car was in an accident) and the alarm went off when I opened the lock through the window. When I went to put the key in the ignition the alarm turned off, but now the car won't start.It doesn't even try to start, you just hear a tick sound when I turn the key. Also now my trunk opener and my power locks switch doesn't work??
Old 01-09-15, 10:19 PM
dicer
dicer's Avatar
Use the master key and unlock either passenger or driver door to cancel the alarm, that will reactivate the starter.
Old 10-09-22, 05:35 PM
bigunit
1st Gear
bigunit's Avatar
Thank you works well.
AustinGard
03-05-17 06:56 PM
se_bb2
16
11-15-16 12:41 PM
TurboPanda
SC- 1st Gen (1992-2000)
08-23-12 07:19 PM
ychachad
10-01-06 05:32 PM
ARM
08-12-05 08:11 AM
Quick Reply: Does 91 Lexus LS400 have a Starter Kill in factory alarm? Help Please Car won't Start
