Part # for 00 LS400 caliper rebuild kit?
As I was working on front suspension, I noticed that the break pads are flush with the rotor surface (breaks not applied) and rotors don`t turn freely(some friction). Does that mean the caliper pitons don`t retract and I need to rebuild the calipers? Anyone has part# for the kit? I read LexLS tutorial, but I know the calipers are different on 1998-2000.
a ancient thread back from the dead....better than me making a new thread ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
is the part # the same for the 1998 LS400's? i got some 1998 ls400 calipers and i figured i would rebuild them before i mounted them but i havent been able to find a part # or them on sewell's page
i searched through all these and found nothing about a part #
https://www.clublexus.com/forums/ls4...ke-issues.html
https://www.clublexus.com/forums/ls4...-pad-wear.html
https://www.clublexus.com/forums/ls4...y-caliper.html
so anyone have a part #? or anyone have a DIY on this either.....im not seeing anything for that either
nor in the sticky
https://www.clublexus.com/forums/ls4...fo-thread.html
nor in the sticky
does the rebuild kit 04479-50091 come with parts to do both sides and does it not come with the fitting kit and anti squeal shim already in the rebuild kit?
the disc pads 04465-50070 im assuming is brake pads? im going with EBC reds so i wont use these, anything else i dont need?
ne DIY on this?
Master Thread Closer!!
ty,
ne DIY on this?
ne DIY on this?
From what I remember, the rebuild kit comes with....
- 8 piston seals (4 for each side)
- 8 rubber boots
- small packet of lithium grease
- 2 crush washers for the brake lines
It does NOT come with anti-squeal shims, you need to re-use the existing ones. Just clean them up and apply lots of anti-squeal grease. Some new brake pad sets do come with new shims. You DON'T need the brake sensor wire.
You will need front RCAs....I don't recommend shaving any bolt/nut. You also need new 95-00 LS400 size rotors, and be prepared to cut or bend your rotor shield to allow space to mount the LS400 calipers.
And don't forget hubcentric spacers....I used 15mm to clear my stock 16" wheels.
Good luck.
Pete
dwebb99
04-15-09 03:54 PM
