Would LS400 '91 rim fit '94 LS400?
Old 01-03-05, 01:21 PM
Lac
Lac's Avatar
Default Would LS400 '91 rim fit '94 LS400?
Hello all:
Would you let me know if the rims of the '91 LS400 fit '94 LS400. Thank you!
Old 01-03-05, 05:27 PM
Kansas
Kansas's Avatar
Yes, the 91 LS rims will fit a 94 LS but most people go the other way and put 93+ rims on 90-92 LS cars. The OEM rims on 90-92 LS are 6.5 x 15". The OEM rims on 93-00 LS400's are 7 x 16". The 90-92 LS came with smallish 205/65-15 tires. The 93-00 LS came with 225/60-16 tires which are much more appropriate for the weight of an LS. The extra section width of the 225's provided much better braking and a bit better handling too. To maintain speedometer accuracy while using 15" rims on a 93-00 LS400, you would have to use something like 245/60-15" tires. This tire size exists but there is not much of a selection.
I recommend against doing this sort of swap unless it is a short term necessity.
Old 01-03-05, 07:50 PM
sniper
sniper's Avatar
Originally Posted by migirdech
i'm not sure if you intend to replace all 4 wheels or just find a single replacement, but be aware that the stock rims for the 91 LS are directional (i.e. side specific as in right/left). i'm not sure if it would be a major issue, but it would probably not look right and might affect airflow for cooling the braking components.
Yup, those wheels are designed to help pull air through the brakes when mounted right. Dont you just love toyota quality
Old 01-04-05, 05:25 AM
Lac
Lac's Avatar
thanks all ... my plan is to install snow tires on '91 rims.
cliffc
08-23-11 04:23 PM
wcoastls
26
05-02-11 09:51 PM
sarel
Wheels and Tires Classifieds
02-28-06 09:25 AM
soarer5780
Wheels, Tires & Brakes Forum
02-28-05 07:37 PM
teeque
01-11-02 09:26 AM
Quick Reply: Would LS400 '91 rim fit '94 LS400?
