2JZ-GTE now sit nicely in my engine bay.
#31
customs 3 inches intercooler piping
Left: Retrodrive ride with big turbo
Right: my ride with stock turbo
Any similarity?![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I just notice that his engine is a bit lower than mine: I think it should be at least 2 inches lower.
Any similarity?
#32
parts that need to ask for when buying used engine : from left to right ....Hydralic fan control, engine ECU, Fuel pump relay. Dealer price for the above part will be expensive.
#34
getting better and better, seems like its road ready,
so when is the final test, hows bangkok streets these days, i guess its still pretty traffic, last i was there was in 95, so probably a lot has change,
#36
Denso Mazda 20B rotary fuel pump. Engine still bog when boost-
will need to figure out what went wrong. I think something in the fuel system was the cause. ![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
ans to Bicol-ini : Bangkok traffic is jam pack ... too many car to little road.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#40
Originally Posted by chuckb
gowest-nice work.
how does the 1uz mustang run in 1/4?
edit-misread your sig 1jz
Will bring the pony to drag strip soon, still wait for part called "traction bar" from U.S. ; the car experience strong wheel hop under hard acceleration. But from my feeling it accelrate faster than my other Cedric with RB26(which ran 14.6 - 1/4mile) so I assume it will be in mid to high 13sec. range.
#41
1. need extra deep # 37scoket to remove this part and replace it with one from LS400 units.
2. I don't have the deep soket so I grind the end tip off about half cm.
3. Easy part is to swap the back plate.
4. not original Toyota part but work fine.
5. Hard part is to remove the whole rear suspension to weld the spacer and measure the level. At least 2 strong men is need
in this part. But if you can weld upside down then no need to remove the whole suspension.
#43
Ohlin - coil over strut from Supra JZA80..I bought it used for $200. The one up front is a bolt on but the one in the back need some modification as picture. This Ohiin unit allow height adjustable up to 3 inches.
