2JZ-GTE now sit nicely in my engine bay.
Old 06-07-05, 01:04 PM
  #76
Richie
Richie's Avatar
Looks mighty impressive!!!
Old 06-07-05, 05:41 PM
  #77
technol
technol's Avatar
wow that car is insane!
Old 06-07-05, 06:28 PM
  #78
loonyrobert3
loonyrobert3's Avatar
WOW it looks awesome and like the new pics!!!!
Old 06-07-05, 09:16 PM
  #79
got_trd
got_trd's Avatar
looking good there.
Old 06-08-05, 01:11 AM
  #80
gowest
gowest's Avatar
Stock twin turbo unit is somewhat big and heavy. I think I save at least 30lb. when converting to single.
Old 06-22-05, 09:43 PM
  #81
gowest
gowest's Avatar
After HKS F-con V 2.1 installation and tune the car still feel laggy. I see full boost at 4500rpm. So I decide to switch the turbine housing from twin chamber .84 to .70. Hope that it will help the spool up time.
Stupid of me. Should stick with 60mm turbo in the first place. Aiming for too much HP make the car not so fun to drive after all.
Old 06-23-05, 02:46 AM
  #82
LexieLS
LexieLS's Avatar
Default Wood & Leather Steering Wheel
Where did you get that steering wheel? Was it speial made in Thailand? Do you mind giving me the contact information of the place where you got it from or where you had yours made. I have a 95' LS and have been wanting to get one of those but all I saw was for 98' and newer and afraid it won't fit. I will be visiting Thailand in 2 weeks and hoping maybe I can get one then. Thank you!!
Old 06-27-05, 06:45 AM
  #83
gowest
gowest's Avatar
48mm Turbosmart wastegate and steinless downpipe
Old 06-27-05, 06:51 AM
  #84
gowest
gowest's Avatar
tranmission coller. the installation look terrible but will work just find. Want to put it behind the right foglight for better cooling but too lazy to remove the bumper.
Old 06-29-05, 06:11 AM
  #85
Lvangundy
Guest
Posts: n/a
WTF. I'm still trippin about how you got that supra rear end in the LS frame.
?!?! I guess it's just a matter of making it fit. blah.
Old 07-01-05, 05:13 PM
  #86
RUDENESS
RUDENESS's Avatar
did you change the rear end?
Old 07-01-05, 06:45 PM
  #87
gowest
gowest's Avatar
Yes, first is 3.79 from Aristo, then 4.1 from NA supra for now.
Old 07-02-05, 12:27 PM
  #88
gowest
gowest's Avatar
Intercooler water spray. Part needed: hose, wind shield washer and one way valve. All for less tham $25.
Old 07-03-05, 03:52 PM
  #89
RUDENESS
RUDENESS's Avatar
cool, keep me posted on how the car turns out, tell me somethng, why didnt you just turbo the stock engine?
Old 07-03-05, 07:46 PM
  #90
gowest
gowest's Avatar
I like the twin turbo V8 but to properly set up the turbo system and fine tune the ECU will require "high engine skill " and a bit more money. Plus the space is so tight in the LS400 engine bay that there are no room for small twin turbo. (SC400 have more foom) For big single turbo you need to relocate the battery to the trunk and make custom header.
And 2JZ-GTE is a direct drop-in with lot of aftermarket high HP part. For 1UZ-FE most part will require special order. : forge piston, rod, header, steel gaskets, stand alone ecu, etc. That when thing getting expensive.
BTW: did you check out "lextreme " yet,he been doing turbo 1uz and lot of info was avaialble.
Quick Reply: 2JZ-GTE now sit nicely in my engine bay.
