upgrade brakes on 90-92 LS?
You would have to change to the 16" wheels.
Supra TT brakes require 17" wheels.
Most of the parts are interchangeable on that family of vehicles.
Todd M.
TM Engineering
http://www.tmengineering.net
Todd M.
TM Engineering
Todd M.
TM Engineering
Todd M.
TM Engineering
Will it just go right on a 93 LS400 without any modifications?
How much for a Supra brake kit?
Steel lines, rotors, calibers, etc.?
My 96 has 12.4" rotors with 4 piston calipers. I imagine you would need at least 16" wheels to clear them. Ask this question on the SC forum as many have done the Supra upgrade and I was told it was very reasonable at around $800.
Lou, I am not sure of the details of the RMM upgrade. Don't they have several levels up to and including super-trick looking (super expensive) stuff? For a show car the aluminum center section with bolt on rotors looks best (formula 1 looking) but very expensive. If set up correctly (important consideration) these brakes should allow racing type performance and repetitive fad free operation from VERY high speeds. That said our cars have pretty decent brakes stock. The Supra stuff may not be bettery than my 96 stock stuff, heck may be the same! The HUGE benefit to factory stuff is availability of service parts. If you need pads, rotors, bearings, calipers, etc, etc it is all available in from any dealer. If you go exotic stuff your car could be sitting for days and even weeks waiting for a replacement part...
