OH NO! p/s problems with my 1990 LS400
Old 04-08-05, 06:51 PM
PlutoBHG
PlutoBHG's Avatar
Default OH NO! p/s problems with my 1990 LS400
Ok,
So i dropped it off to get a checkup, and im told that the p/s pump/pressure hose/steering rack
are all leaking and that the parts would be 1200$ and labor 500$...i looked the parts up online and i found them all for about 700$
was wondering if anyone has ever replaced all of these and how difficult it would be because i do have access to a garage and tools...all im lacking is the book...
thanks for your help again!
-PlutoBHG
Old 04-08-05, 07:05 PM
TLW
TLW's Avatar
welcome to CL
contact club lexus sponsor JP imports
he can help you out ..or at least lead you in the right direction
-johnny
Old 04-08-05, 07:06 PM
TLW
TLW's Avatar
wait
did you notice all these things leaking ?
do you leave any wet spots when you park ??
have you looked under your car??
have you considered Lucas products ??
Old 04-08-05, 09:59 PM
LexLS
LexLS's Avatar
Download the book from TIS (Toyota info): http://www.lexls.com/repairmanual.html
Yes, a leaking PS pump is a very common problem. Basically, the seals inside the pump deteriorate over time and need to be replaced. You, or your mechanic needs to rebuild the pump. They make a rebuild kit with all the gaskets you need for $25 or so, a new bearing is about $10. I'm getting ready for a PS pump rebuild myself....
Old 04-08-05, 10:19 PM
PlutoBHG
PlutoBHG's Avatar
what about the hose and the steering rack? to answer the other question, i have not seen them all leaking no i do not know exactly where to look, i do know they are leaking, i leave wet spots, and it smokes when i start it after sitting for a few hours from the leaked fluid burning up...also it dried up completly a week ago and i had to refill it...they told me the pressure hose and the steering rack also need replacing though also, i looked up instructions on how to rebuild the pump and i figured i would do that but im not sure if i need to buy the hose and the steering rack also, im thinking about taking it to a couple more places to see if they say the same thing.
any more advice would be greatly appreciated
THANKS AGAIN!
PlutoBHG
Old 04-09-05, 08:27 AM
LexLS
LexLS's Avatar
It is definitely possible that all three need to be replaced. I had a leaky steering rack myself and had my mechanic replace it. The pressure hose is probably just a good thing to replace because it too may be leaking.
I think you should just bite the bullet and get it all fixed........
Superfast1
28
11-23-22 04:59 PM
hokiebrewr
07-16-18 12:52 PM
LexiiBelle
14
02-05-16 10:17 AM
sayow
11-14-13 05:32 PM
Bradster
07-27-04 08:27 PM
Quick Reply: OH NO! p/s problems with my 1990 LS400
