Shift knob replacement?
VIP 様式
There is a ES in the gallery on pg3 bottom left with a Levoc shift ****,will this work with the 1st gen. LS 400.
because nobody knows where to get a wooden shift **** for the 1st gen LS,so i wonder if Levoc has a wooden one so i could replace it with the stock ****.First i need to know if the Levoc would work on the 1st gen. LS.
They do have one and it does fit, but I don't like it because it has some chrome around the wood and thus doesn't match the interior at all.
I believe the price for it is around $120.
VIP 様式
Loule,i do not think it looks that bad since it has wood on it,but are you sure Levoc has a wooden one and it will work for our LS's.
Man it is pain trying to find an importer for a bodykit,still no luck,and i am scrambling to get my car done before school starts again.I got about ten things to do on my car and stuff,probably way in over my head.
I like the look of the **** by itself but I don't know about actually IN the car because there's not any other chrome inside. I'd have to see it to really make a decision. I still don't think I'd get it for mine but I don't want to pimp my LS out the same way Edogg does.
Edogg, I saw your car in the gallery. Your $h!t is tight.
Like I said, I like it but there isn't anything chrome in the Lexus.
VIP 様式
In my LS there is, below the stick i put a chrome engine plate with the Lexus sign on it and it looks pretty good with the wood. There for i have a square of chorme with a big L on it, i think it would go good with the chrome wooden ****.
Zushwa my car looks okay right now,just wait a month or two,it will completely be a new car.
VIP 様式
I do not know how Loule, i have no scanner or digital camera and i am not that good in computers,but i will try at my friends maybe.
I also got the the smaller L for the lexus emblem and glued it to my sterring wheel.It is the same size and exact fit.
VIP 様式
Hey Loule,i have noticed that the od button is different from 93 and 94 it is on the left side right,but my od is in the front,do you still think the wooden levoc **** would still work?even tough the od buttons are on different locations.
Your gonna have to splice into the OD button wires and connect them to the Levoc **** either way because the OEM harness won't fit.
The Levoc **** is made to be universal so it won't have a harness to fit the LS.
Will the Levoc Wooden Shift **** be an easy task to do by yourself or should i take it to a shop to do it?
It should be pretty easy to do.
Edog, did you ever end up installing the chrome/wood shifter? Did the wood portion match up with the OEM wood well? How was the install and would u recomend it? My shifter needs replacing or recovering, the leather is shot.
TIA
TIA
VIP 様式
TIA
TIA
