PSI on bigger wheels
Love the ride! Car looks great with those wheels and tint. 2x
I noticed in your earlier post that you mounted 235/50/18 instead of the stock 245/45/18.
I did a little research using the tirerack and noticed the following:
1995 Stock Tire Size---Standard--------Front Optional---------Rear Optional
16 inch---------------------225/60-16
17 inch---------------------225/55-17-------225/55-17--------------245/50-17
18 inch---------------------235/50-18-------235/50-18--------------265/40-18
19 inch---------------------245/40-19-------245/40-19--------------275/35-19
19 inch---------------------245/35-20-------245/35-20--------------275/30-20
The tire size for 1995-2005 are all the same.
The only difference is that in 2004-2005, Lexus used 245/45-18 instead of the tirerack's 235/50-18.
Questions:
1.dolefee- Why did you choose the 235/50/18 and not the 245/45/18 ? Was there a fitment issue?
2.dolefee- What brand tires do you have? Are you happy with them?
Check out the following site and see how your tires compare to stock:
http://www.miata.net/garage/tirecalc.html
According to that site, the 245/45/18 is a better match to stock than the 235/50/18 .
Questions:
I went with the 235/50/18 oppose to the 245/45/18 for (2) main reasons:
1. The 18" OEM wheels are 18 x 7.5 and MY rule of thumb is that an 8" width should call for 245s.
2. I wanted to maintain the stock ride comfort as much as possible, and I think I was successful at that.
I have ALWAYS lowered my vehicles, but I have no plans to lower my LS. I just wanted a better looking stock wheel. I have about a 3-finger gap in the front(due to the front wheel well being cut higher for steering purposes) and a 2-finger gap in the rear. As for the tires, I went with the KUMHO ECSTA ASX and so far I have no complaints. Quiet, 420 treadwear, and at a good price.
VIP|EXEstyle セルシオ
To answer 93LS's question
https://www.clublexus.com/forums/sho...11&postcount=6
taken from this thread:
https://www.clublexus.com/forums/sho...d.php?t=155020
93LS, keeping in mind that I have the same setup as you, but with Michelin Pilot Sport A/S tires, my calculation turned out to be 34.9 psi.
Most if not all factory Lexus wheels are a direct swap onto the 1st gen LS.
SC430 wheels on my '91.
dolefee, wheels look great on the car even though it's not lowered.
Originally Posted by lino
I'd like to see how other factory Lexus wheels look on older LS400s. Are they a direct swap?
Thanks BR1AN,
I will do the calculation after I get the info from the wheels tonight.......
for now I reduced it to 36 PSI.
pictures will be coming soon.
93LS
93LS
Originally Posted by GRAND_LS 4
No, 2nd gens have the bigger 4-piston caliper, so fittment is an issue with most of Lexus' wheels. The SC430 rims DONT fit the 95+ LS.
So are there any factory wheels that do fit the 95+ LS?
AL13NV8D3R
RC F (2015-present)
03-11-15 05:45 AM
Bowlth
08-27-08 07:21 PM
Morrissey
01-21-06 03:12 PM
