Foglight mod for 98-00 LS COMPLETE!!
#61
From what the diagrams provided in this thread of what the relay does.. the oem switch when turned on completes the ground circuit?
Id have to take the relay apart and play with it to see what it actually does.
They method I described is still using the oem relay plugged in. Just changing one wires power source.
If i were to pull the dash apart and saw a harness and relay hooked up I would scratch my head for at least 1hr. But the way I described one wire changed would be easier to figure out just by looking at wiring schematics.
#63
Sorry to re open an old thread but this is as close as I’m getting, my fogs don’t work, the bulbs are fine, fuse is fine. But I have yet to locate the relay, I see the pictures provided but they all say “please visit blank blank to unlock these photos” is there anyway someone could post again where it is in car, thanks.
#66
The relay is under the drivers dash near the kick panel. It’s attached to a white plastic mount that holds other relays and I think the fuses. You have to remove the black plastic to get to the top of that plastic piece
http://i1200.photobucket.com/albums/...s/DSC00614.jpg
jeffgwaltney
07-07-17 02:58 PM
