Air Conditioner OUT A/C NEED HELP
Old 07-06-05, 08:41 PM
nikunj78
nikunj78's Avatar
Default Air Conditioner OUT A/C NEED HELP
Hello,
Need some help, my air conditioner is not working properly in my 1998 LS400. The air is blowing, however its not as cold as it should be. When i hold my hand up to the vent, it is colder than the air that is making it to my face. With 105 degree weather, this is beating me down. HELP HELP, i have checked the a/c filter and nothing wrong with that. I have bought a new air filter thinking this may be the problem, but just don't know where to install the darn thing. HELP HELP. PLEASE.
THANKS
Old 07-06-05, 09:01 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
It's not your air filter. Sounds like you ran out of freon....take it to a local mechanic who can recharge the freon for you. Or, if you must, take it into the dealer.
Old 07-08-05, 07:53 AM
LexLS
LexLS's Avatar
Yup, you need a refridgerant recharge. 98's have a r134a system right? If so you can diy easy for like $30, I did with mine, took about 10-15 min. I've got a tutorial on this coming soon on my site.
Old 07-08-05, 09:13 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Are you have this during start up? it takes a while for it to cool. My system is perfectly fine, but after sitting in the 100+ weather down here, it takes a while to get cool.
Or doesnt NEVER get cool even after 10mins for driving?
Old 07-08-05, 01:25 PM
RPH74
RPH74's Avatar
You're definitely low on refrigerant. Yours uses the newer R134a, which you can buy at WalMart or any auto parts store quite cheaply. It would be easiest to buy one of the cans that has the hose attachment and gauge on the can already. To charge it, all you have to do is run the A/C and connect the hose attachment to the low side. It is much like adding air to your tire.
You will notice 2 different A/C ports, one is called the "high side" and the other is the "low side". Usually the low side is the port nearest to the compressor. Even if you're not sure which side is which it won't matter- the hose connection will only fit the low side!
Hold the can upside down when charging, and don't overcharge it!
Retroplay
01-06-16 06:05 PM
kidluvsole
06-26-08 08:35 AM
kidluvsole
06-24-08 01:59 PM
Quick Reply: Air Conditioner OUT A/C NEED HELP
