fuel pump problem?
fuel pump problem?
okay so i have some bigs plans for my car and i was just about to start when my car started acting up. During normal driving the RPMs might just dropp and i might give it some more gas and nothing will happen then it will jolt back up and go again just to continue to do the same. I have no idea whats wrong, its not the gas and its been happening alot lately
if anyone knows whats wrong could u please let me know. if it is the fuel pump and if i need to replace it ,no problem.
Super Moderator
My situations with the fuel pump is it either works or isn't. One instance I did have in another car was the car would seem to stop and resume running...that lasted about 10 seconds before the pump quit completely.
Some other thoughts:
throttle body and linkage
plug along with ignition wire/s
ignition rotor/s
MAF
ignitor/s
battery cable loose
fuel filter...
Any warning lights lit up on the dash when this occurs?
ignition rotor/s
MAF
ignitor/s
battery cable loose
fuel filter...
ignition rotor/s
MAF
ignitor/s
battery cable loose
fuel filter...
ignition rotor/s
MAF
ignitor/s
battery cable loose
fuel filter...
MAF
throttle body
fuel filter
if it was the ignition rotor, ignitor or loose batt cable it would happend all the time
LoveSCs
Performance & Maintenance
11-04-21 11:41 PM
Qcollons
09-17-11 06:22 PM
