Knocking from front end.....
Old 09-21-05, 08:22 AM
Quiller
Quiller's Avatar
Default Knocking from front end.....
Anyone know which bushings to replace and where I can order the parts? '91 LS 400
The front end knocks when even the slightest bump is run over. I have jheard that some parts suppliers sell the control arm with the bushings pressed on. Can I just replace the bushings or should I find the suspension arms with the bushings allready on?
Thanks
Quiller
Old 09-21-05, 09:05 AM
Lexozz
Lexozz's Avatar
Depending on how much the press-in bushings cost. I've replaced mine about four years ago and I paid $140 for both arms from the dealer. IMO it's probably easier to just place the whole thing and less time consuming.
Old 09-21-05, 10:19 AM
damon
damon's Avatar
90 LS w 217,700
Just installed the following in the front suspension of a high mileage 90 LS 400. Note most "paired" parts indicate right & left.
43340-59016
43330-59016 Lower Ball Joints
48510-59017 Struts x2
48610-50020
48630-50020 Upper Control Arms
48654-50010 Lower Control Arm Bushing x 2
45700-50010 Steering Damper
Waiting on:
48810-50011
48820-50011 Link:
Both front Tokico Shocks (non oem) & the Damper had no rebound whatsoever. $1000.00 in parts and $500.00 in labor.
This LS is on it's 3rd set of Struts.
Old 09-21-05, 11:29 AM
john1529
john1529's Avatar
Thanks
Quiller
I replaced just the lower control arm bushings on my '97. Purchased through irontoad.com for $76 total. PIA to get the bushings out even with a press but other than that pretty easy. Remedied the "clunk".
shurian
Suspension and Brakes
77
03-31-15 05:58 PM
ATLs460
RX - 1st Gen (1999-2003)
05-13-14 07:26 PM
akxx
04-06-07 11:39 AM
persian451
10-22-03 10:33 PM
damon
07-09-03 11:22 AM
Quick Reply: Knocking from front end.....
