90-94 Rear Suspension Questions (Non-Air)
Never noticed this before & can it be right?
Do the Lower Control Arms (48730-50010) & the Strut Rod (48780-50010) use the same bushing (48725-50020)??
Is there a bushing replacement for the "Front Arm" 48710-50020 & 48720-50020??
Thanks, Damon
My Current replacement list:
Upper Control Arm
48790-50010 Lt.
48770-50010 Rt.
Coil Springs X 2
48231-50020
Rear Struts X 2
48530-59056
Arm Assy., RR Suspension X 2
48730-50010
Bushing Only X 2 (48725-*****?)
Front Arm/Control Arm
48710-50020
48720-50020
Bushing Only X 2 (is there a bushing option?)
Strut Rod X 2
48780-50010
Bushing Only X 2 (48725-22110) note: Edited
Stab Bar Link X 2
48830-50020
Stab Bar Bushing X 2
48815-50030
Thanks, Damon
Upper Control Arm
48790-50010 Lt.
48770-50010 Rt.
Coil Springs X 2
48231-50020
Rear Struts X 2
48530-59056
48730-50010
48710-50020
48720-50020
Strut Rod X 2
48780-50010
Stab Bar Link X 2
48830-50020
48815-50030
I know that Steve et all at armstrong do make these two specific bushings.
some info's here... https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/86781-rear-tie-rod-assembly.html
blech, got busy & lost train of thought !
Traturn,
I remember some old post where you have gone thru some of this process before, so thanks for the help.
I think the # I meant to post was 487525-22110. It is a strut rod bushing.
Sewell online also has it listed as a "front arm bushing"??
Gave the parts a visual once over today. None of these bushings are the same on the different part #'s.
This 90LS will have a new suspension front & rear. Cost will be about $3000 after install but the engine still purrs after 220,000 miles so we will see how far it goes.
oarnura
16
11-10-10 09:03 PM
4823150020, 4871050020, 48730, 4883050020, air, arm, coil, control, lexus, monroe, number, part, rr, shocks, spring
