big systems in ls 400
whats up i got some info on anyone looking to put a system in there ls,i have a 1994 ls with 4 tens and around 3500 watts.if you are going to put a system in your ls. keep in mind that the trunk is totally sealed,because the gas tank is behind the seats(i gues for safty),so heres what you do.......
1.take the factory sub out and you use that hole as a pass through from your trunk to your cabin(cheapest way)
2.drill holes in your back dash to make more pass through holes(kinda diffuclt not really worth it)
3.get a box built,so that the port will come out on your factory 8 inch sub hole.(costly)
4.find a free air 8 inch sub(wont really sound as good as a 10,12,or15
i did number one,and it does not really sound as loud as i want it to but it sounds really really clear and deep,i hope this info helps every one out..
biglexass
biglexass
Im going to cartoys soon to get a system in my new lexus. I already have my JL audio wedgeseries subs in the back waiting to get hooked up. So I should I just have them take out the old sub?
I was actually thinking of going with step 3.
Getting a ported box built and having the port hole
on the stock 8" hole through the back deck.
Do you have any pics of your setup?
Im only going with a simple setup not too extravagant.
Did step one, just finnishing up my fiberglass box to hold my two 12" type r's. mmmmm cant wait, and itll be a sealed box as i like my subs hitting quick. To be honest i dont think there will much a difference between step one and step three, but to each their own...
https://www.clublexus.com/forums/sho...d.php?t=175609
I feel your pain.
I still don't know how to get around this problem because my freaking juggernaut is DEAD!! (grr.. long story)
I feel your pain.
I am in the process right now. (Nakamichi head unit) Temporarily 4" 2-way Kappas in the front and rear doors, stock sub and stock tweeters. I'm running an A/D/S 4 channel amp and Alpine Vpower mono amp. As of right now I will be running the door speakers and tweeters off of the A/D/S. The stock amp will be retained for the stock sub at this point. I'm also not sure if I can eliminate it completely.
In the next couple weeks I am going to replace the tweeters and install 5.25 woofers in the front doors. I'm also adding some type of sealed box sub 10 or 12", haven't decided which the Vpower will power. My line level converter should be here tomorrow and will be able to test out my creation!
Bigger Speakers in Doors???
I have a 95 LS 400. I am wonder whats the bigggest size speakers I can put in the doors without modifcation to the stock enclosure?
With modifivation done ehst sizr eill I be able to fit? Any pictures of a 95 Up LS with bigger door speakers? Any Help will be Appreciated!
Thanks!
Thanks!
The scosche line level converter worked!
I ran speaker wire out from my amps into the speakers and wired the wires coming out of the factory amp into the input of the converter. Then I ran the front output of the converter into the 1 and 2 channel of my amp and the 3 and 4 channel to the rear speakers. This was also branched off into the Alpine mono amp for the single 12" woofer as well. I have to finish soldering up the wires and mounting everything. System sounds great and I retained the factory deck!
I have a 12" kicker sealed sub in my trunk along with an Audio Bahn 8" in the rear deck. It did increase the bass by alot, but the down side is that one doesn't sound good with out the other.
Thanks!
Thanks!
https://www.clublexus.com/forums/sho...d.php?t=163264
Thanks!
Thanks!
by the way, i did not have to cut the factory door panels in any way. the 8 inch driver DOES NOT hit the door panel grill either (especially when playing). the door itself acts as the enclosure. if you were to open my front doors you would not know i had 8 inch drivers becasue it still looks like STOCK!!!! Woo Hooo!!!!!
6 1/2 drivers
Originally Posted by vsynergy
wow mtaalib, 8 inch drivers? i'd like to try to make my own enclosures for 6 1/2 drivers in my '90.
mmorozov
08-27-08 06:23 PM
OGS
12-02-05 04:18 PM
