Water in Trunk
Same problem happened to me. Turned out to be the gasket on the power antenna. Put silicon between gasket and car, tightened antenna then cleaned off excess. Problem solved.
Hopefully, some of you will have this simple fix.
BTW, the compartment under the antenna filled up before the compartment for the spare tire did.
Tote
Tote
Mine was a combo of weather strip and silicone sealing the trip piece above the seal underneath the window. water would get in that way.
topgun129
01-24-10 07:38 PM
