Gas Mileage Problems...TOOO LOW!
#46
ok...that's correct in it's own way. But then why would you buy a premium car that requires premium fuel and give it regular? Being cheap? that puzzles me. Would you go buy a Ferrari and put 87 octane in it just because it will run fine as long as you don't redline it??? ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
now as to your other question, i don't know the answer, as i always use premium if the engine was designed for it. i like to go full throttle to redline pretty regularly and i want all the power that was engineered into the engine.
every vehicle i own requires premium and i use it to maintain maximum performance.
for some people, i guess it is cheapness and not understanding the true effects of preimum vs. non.
since most ferrari's and other super high end cars for the most part never see wot or redline like they were intended to, i suppose some owners would justify that as a reason to use 87.
should lexus owners use premium if they never go wot to redline? that's up to them; as they really don't have to since there will never be any negative side effects at low loads.
#48
well... it is correct absolutely; that's how it works, bottom line. (not trying to be an ***, i just don't know any other way to say that)![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
very well put 19.
#50
it'll be at rest until someone else brings it up hoping they well get our blessing to use 87 in their premium only engine....
i should do a write up on exactly what the octane numbers mean and how it applies to our engines and make it a sticky...
#51
YES YOU SHOULD!!! I hate it when people argue with me to use 87 octane...As if the big glowing neon sign on the guage cluster isn't large enough.
One thing I was suprised about.... My sister's 07 Mustang GT calls for 87 Octane....4.6L 300hp 320ft lbs high performance engine designed for 87 octane??????? I guess it IS just an American car! Hahah
#52
#53
i'm surprised that mustang only needs 87 as well. i thought it was a high compressoin engine. my LS1 camaro needed premium! of course, z28>mustang GT...
i may work on that write up on octane and post it and let the mods sticky it....
#55
#56
Thats more like it! 200k seems to me the most to get out of an American car. 300k out of most imports (japanese) and 400-500k for Lexus
. as for VW and other german cars, It makes me sad when people buy them. hahaha
#57
#58
So..... LOLZZ
Can I use 87 octane in my 91 lexus instead of premium LOL? Its cheaper and i want to save money LOLSSS.
Will my car run zLOLz fine? What are some of the LOL advantages and pitfalls to doing so?
#59
do you ever floor your car and take it to redline? do y ou drive it hard? if no, then you don't have to use 93. it will run fine. just don't expect full power the day you have to stomp on the throttle to get out of the way of a bus or something....
really how much cheaper are we talking though... .20 per gallon, so about $3 if you fill up with 15 gallons. i'd rather have full power all the time for $3.
