Gas Mileage Problems...TOOO LOW!
Old 10-09-05, 10:40 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
Default Gas Mileage Problems...TOOO LOW!
yea, im getting maye 200ish miles on a tank of regular. with the 22 gallon **** that means im getting LESS than 14mpg. the air filter is decently clean and i think the plugs were replaced about a year ago. anyone have any ideas with whats going on!??!
Old 10-09-05, 11:59 AM
ychachad
ychachad's Avatar
14mpg sounds OK especially since you have not said what kind of conditions you are driving in, and if you are indeed doing stop-and-go in the city. Besides, you are using regular gas. Why? Your car needs premium. So you can expect even lower gas mileage when you use regular, as your car will retard the timing to compensate for the loss in octane.
Old 10-09-05, 12:08 PM
sha4000
sha4000's Avatar
[B]my mpg has really gone done since ive been doing mostly city driving. short trips with lots of idling im probably getting a little over 300 miles on a tank
Old 10-09-05, 12:26 PM
TJW98LS
TJW98LS's Avatar
Sha Im with you I do about 14 miles of city driving and 14 miles of highway driving a day and I get just over 300 Miles to the tank. That's only to school and back, and any other trips are more so I fill up about every...6 days or so.
Old 10-09-05, 12:41 PM
PureDrifter
BahHumBug
at this point i would LOVE 300 miles a tank. these days im barely getting 200!!
would changing the plug help with this, i dont really wanna do the wires right now but eventually il change the caps+rotor and the wires...but for now il just try the plugs. any reco's on which plug to use?
Old 10-09-05, 01:03 PM
sha4000
sha4000's Avatar
is your tire pressure the same all around?and are you carrying alot of weight in the trunk?that is crazy b/c your barely getting 10miles a gallon. is the check engine light on?
Old 10-09-05, 01:20 PM
RA40
Super Moderator
RA40's Avatar
Lots of threads on this.
Definitely use premium as ychachad said.
On the highway, enough of us are getting better than 26 MPG with some at 30. Unless your engine is tired.
Keep excess junk out of the car...excess weight uses more gas.
I changed the air filter last week and it is looking like I got back that 1-2 MPG. I didn't think it was too dirty but it did have 30K on it. Was getting about 24-25 MPG prior to the change now it should be back to the 26-27 MPG.
Old 10-09-05, 03:09 PM
PureDrifter
BahHumBug
what il do is let this tank finish up(1/4 left) and record the mileage. then il fill it up with some premium and see what mileage im getting. if its significantly higher, il switch to premium since the mileage benefit outweighs the higher cost, if its only like 1-3mpg more then il stay with regular/middle grade.
any advice on fuel injector cleaner or spark plugs/wire/rotors+caps? and i think the air filter was done less than 10k ago.
Old 10-09-05, 05:56 PM
ychachad
ychachad's Avatar
The car needs premium gas - mileage or not. you insist on regular after that, you are asking for trouble. premium gas is not going to double your mileage. again you don't tell us about what kind of driving you do.
Old 10-09-05, 06:01 PM
sha4000
sha4000's Avatar
even on regular gas he should still get better mpg than that, of course premium will make the mpg a little better
Old 10-09-05, 06:23 PM
PureDrifter
BahHumBug
sorry if i forgot to mention but my driving mostly is a mix of city and highway being about 60/40 city/highway.
Old 10-12-05, 09:23 PM
afaleti
afaleti's Avatar
Default I get about 425 Miles to the full tank ...
Ever since the price of Gas went up, I changed my driving style to cruising , added more air to my tires, changed my dirty air filter and I go almost 1 week to a full tank (17 Gallons) - 425 Miles - I drive about 45/15 Highway/City Daily
1999LS - 75K - 16IN Stock - 93 Octane
Old 10-13-05, 08:01 AM
sha4000
sha4000's Avatar
im prett sure you have a 21.5 gallon tank and thats good mileage
Old 10-13-05, 11:33 PM
JDMUSCLE
JDMUSCLE's Avatar
hey man, that very bad....i have hit high 400's on a full tank with all highway driving and mixed driving has yielded me over 400. this was on my previous 95 LS400 with about 50k on it. The one that i just bought recently gives me about 160 miles for about 6 gallons, which is pretty good considering i have the a/c on all the time and do 60/40 city/highway driving.
Old 10-14-05, 05:44 AM
Lexozz
Lexozz's Avatar
Same here! 400 miles on a full tank, all highway with a/c and roughly between 300-325 city. I still have the original gas filter, air is pretty decent.
Quick Reply: Gas Mileage Problems...TOOO LOW!
