best intake for a 95 LS400
Originally Posted by JDMUSCLE
Hey fellow ls400 owners, which intake do you guys think is the best for a 2nd gen ls400. i have seen a lot of people with the injen. what do you guys think of this intake? thanks for all the info in advance!!!
Check out my DIY thread here:
https://www.clublexus.com/forums/sho...986#post575986
Tis true, stock air boxes, are designed to pull in cool air while trying to lower sound levels. Usually the power increase from those intakes comes from a better free flowing, filter and no box to baffle noise, I think there is also a resonating duct that helps keep noise down in the stock tubing, it'll cause more turbulent air but that only effects it a little bit. (Air filters are designed to clean air and smooth turbulent air thats why you see a small power increase from having no filter to puting on a quality filter)
edit: why do people call this an intake? Everytime I think intake I think manifold
The resonator in the stock system actually INCREASES power It is a helmholtz resonator. Check out these links:
http://planetsoarer.com/resonator/resonator.html
http://planetsoarer.com/resonator/Re...rsAcoustic.htm
BTW, love the old Chrysler Challengers and Cudas. Also loved the old Chargers, Roadrunners, GTXs, and of course the wing cars. Personally I like the 1UZFE engine in these Lexus cars but am seriously considering a 346-427cid LSx based EFI engine swap. All aluminum with tons of aftermarket. Small cam would be very smooth and fuel economy would rival current numbers. Torque would be massively improved.
Well i recently went to Autofashion and they said that they got a new intake company that is making intakes for all Lexus models and i just put a order in for my LS430 and from the dyno charts on the site it looks pretty good. Im not going to race my car but any type of performance upgrades would help.
Go check out the new intakes:
http://*****.com/index2.html
If they dont list it on there im sure there going to make one. If you want one made for your car you can call up Autofashion and they can either get you on the dyno or get you the intake if its already been tested.
I am open minded but skeptical of manufacturers claims for many reasons. One BIG problem with intakes such as these is the pick up point for the air cleaner. Is it isolated from the underhood heat? With an open hood during a dyno run an open element filter will do fine but with the hood closed is begins breathing engine and radiator heated air and the power drops often below a stock filter.
Now, regarding the dyno charts, 5hp is acceptable without any tuning. I picked up about 5rwhp based on drag strip back to back multiple runs. What is NOT believeable is giant spikes in the low RPM torque curve. Manufacturers fight hard to get low RPM torque and it is VERY hard to improve this area of engine performance. Higher flowing filters can possibly help high RPM power where flow can become restricted but the low end is hard to help. Now, if you can and do adjust the air/fuel ratio or ignition timing you can get gains but these intakes do not appear to have any ECU adjustment at all.
I went first to the LS430 dyno and was very surprised to see the reported mid RPM torque increase of over 20lb/ft at 3800rpm. That throws up my BS meter quickly. Then I checked out other dynos and the Chrysler 300C has even more dramatic mid RPM gains REPORTED of 58ft/lbs at 4000rpm... I am sorry but I cannot believe half of that. The manufacturer would pay HUGE money to gain that amount of torque. But what had to be the BIGGEST percentage BS flag for me was the Altima V6 with nearly 55lbs gained at 3500rpm.. I am sorry but there is NO EFN WAY that 3.5 liter engine gained anywhere close to HALF of that claim let alone 55lbs... that is low boost supercharger/turbocharger territory. Any manufacturer putting up claims like this has lost credibility from me big time.
There are MANY ways to manipulate dyno readings. When I see completely ridiculous claims that is the first thing I think of. Of course you can DRAW any dyno line you want. So, without performance testing results (independent when there is a loss in cred already like this) then I would not believe anything they say.
Everyone should at least review the links above I posted. There is a REASON that manufacturers spend substancial money to engineer and install helmholtz resonators on their engines (Hint: to gain torque). Remove them at you loss.
Let me say at least one positive thing about these intakes... the pipes are shiny.
Originally Posted by DoubleWhoosh
Drop in K&N, that will be your best intake
Not to mention the cost, its a pipe with a quality filter on the end of it.
