Aftermarket exhaust gain?
The Green Grundel
So I want to get just a tiny bit more horsepower out of my car plus with the bodykit coming I need an exposed exhaust. I was looking at this:
http://www.luxurymods.com/ProductDet...D=984&fid=1001
I was wondering if:
A) anyone here has it
and, B) What kind of performance gain can I expect?
I figure if a new exhaust for a tiny 4 cylinder honda can get 8-12hp gain then this'll HAVE to give me that or better.
I was wondering if:
muffler delete mod will be better than this mod, due to even reduced restrictions, and less weight.
you can expect 2-3HP. I don't believe for a minute that the Honda muffler change can give you 12 HP.
VIP|EXEstyle セルシオ
Yes, they'll fit on a '95.
http://www.jic-magic.com/productsjic_bullet_twin.htm
BTW, a member (gtfour43) is selling his titanium JIC's for a great price in the classifieds:
https://www.clublexus.com/forums/sho...d.php?t=180460
The Green Grundel
I was looking at that exhaust and considering buying it but:
A) Will it fit a 99'?
and
B) I could be mistaken but those tips really look like the huge exhaust ricer fart cans and I couldn't want that less for my car. Perhaps its just the picture but i'm looking for a modest exhaust, however if the cans look like this:
Then maybe i'll get it
and
yes you can build an exhaust for less money, so to speak. However the quality might not be that great depending on where you go. There are two types of exhaust systems you can "make". One type uses Crush bent Piping, and the other uses Mandrel bent Piping.
For the most part, performance minded heads will tend to gravitate more towards a "Mandrel bent" type of exhaust system, where the inner diamater of the pipes are constant troughout the exhaust system. This lends to a cleaner exhaust flow with less back pressure, a good thing for those looking to eek out every possible pony. Mandrel bent systems can come by two ways. One is where you section off pre bent pices of tubing (avaliable trough parts suppliers like JEGS) then cut, aling and weld to your liking. the second way is to find a place that has a mandrel bending machine and have them bend out an exhaust for you. (expensive!!!)
the other type of exhaust you can make would be "Crush bent piping". this type of exhaust can be made at most any muffler shop with a pipe bending machine. This tends to be the easiest type of exhaust to make, and thus, the cheapest way to make a one off exhaust. however as the name implies, the pipe is crush bent, meaning that there is a kink at the bend in the piping. Which lends to poorer performance, when comepared to its mandrel bent counterpart.
As for the LS400. It seems to me that the exhaust from the factory is already mandrel bent and dose not seem to have any major bottle necks along the way (as far as pipe diameter goes). Remember that these cars were top o' da line back in the day. And Crush bent type exhausts are generally found on lower end cars like civics or carollas, not on yakuza mobiles. .
which means that the factory left room for improvment (as far as the exhaust is concerned)
and the claim of a 8-12 hp gain is not too outlandish, just remember that most dyno numbers that an aftermarket supplier gives for a given part dosent mean that that was the only part tested to produce said numbers.
ie cat back exhaust system on a civic ex = 8 hp gain. What they dont tell you is that to get that 8 hp gain, the exhaust was tested in conjuction with an intake and a headder!
When I say exhaust system I mean the whole system, from the exhaust manifold (header) all the way to the exhaust tip.. A "cat back" means catalytic converter back. Most modern cars have two cats. and a "cat back" system will generally be from the second cat (furthest away from the engine) which means that if you get a cat back, you still have the stock pipes leading from the headders to the new exhaust. ie bottle neck!
i agree with ychachad, go with the muffler delete mod
The Green Grundel
Thanks for the write up! Thats makes alot more sense to me now!
I guess my next question is... how do I do the muffler delete mod?
EDIT: I found this article:
https://www.clublexus.com/forums/sho...ler+delete+mod
But I don't want my car to sound louder I just wanted it to sound deeper/richer... G35 with borla exhaust type sound
it all depends what you want to do with your money.. lets see:
spend very little money and free up most HP possible: muffler delete mod and run straight pipes.. or just muffler delete.
or
Spend a lot of money : and buy JIC or Borla, etc.. in order to free up a similar amount of HP, but have a "nice" sounding exhaust.
If you ask, my understanding is the muffler delete, doesn't really increase the sound significantly.
or
As the "inventor" of the LS400 muffler delete mod I can say from experience that this does not make for a loud car but it is obviously louder than a stock 400. Some of the cabin sound increase is due to the fact that the exhaust resonates between the road and the bottom of the car. Pipes to the rear will reduce this very nicely. The middle mufflers or silencers actually do a very good job muffling the car and definitely qualify as mufflers from a legal standpoint.
This mod is SO EASY just do it and decide for yourself. However, do not expect any power increase from ANY changes from the stock middle mufflers. Headers are now available and there is a very comprehensive condensed thread in the GS section about them.
The LS400s do have several restrictive areas. Removing the back mufflers and replacing them with straight pipes is inexpensive and it will not hurt to use crush bent piping if this is your only change. Search under my name in this section for a LOT of exhaust info.
