How to Fix Power Seat? (warning pictures)
Hi, i have a 92 LS400 with the power seat problem described here:
http://www.cureline.net/lex/howtos/info_seats.htm
Anyway, here's a picture of the whole seat opened up:
Pic 01
The arrow is pointing to the problem area. Here's a closer picture of that area:
Pic 02
Anyway, that's black rod in the picture is turned by a motor on the other side of the seat. The rod is supposed to fit into a "splined shaft" on the other side (circled picture 2), which turns the shaft and raises/lowers the seat. I've tried to slide the rod more towards the right (center console side) of the seat, but its not really budging.
What tool(s) have you used to get the rod of fit over the shaft?
Also, for reference, he's a pic of the motor on the left (door side) of the seat:
Pic 03
Thanks
Pic 01
Pic 02
Pic 03
Thanks
If anyone is interested, i was able to fix this problem, at least for the time being. Ultimately, the solution did involve Krazy gluing the rod to the adjustor, but i ended up removing the entire backrest to get to the problem area. Sadly, i didn't get a picture of this, but trust me, it wasn't pretty.
I had to "peel" back the leather a bit to reveal 3 bolts on either side of the seat. These bolts hold the backrest to the adjustor arms. I found that the teeth on the adjustors had worn a bit and the rod was about to turn without engaging the teeth. I don't like using glue to fix anything, but in the case, it seems to be working.
theBishop
10-14-05 07:37 AM
