Best Spark plugs?
Old 10-17-05 | 03:50 PM
TJW98LS's Avatar
TJW98LS
Default Best Spark plugs?
It's about time I replaced my spark plugs on my LS. What are the best I can get?? Is there anything else I can get to do to make my gas mileage any better?
Old 10-17-05 | 07:44 PM
ychachad's Avatar
ychachad
Replacing an old plug with a new one may improve your mileage "although not noticeably". Just about any platinum will work. I have used Bosch platinum, Platinum +4, and ND irridium with good results, but none provided better mileage or power than the other. If you want to save $$$, go with the cheapest Bosch Platinums.
Old 10-17-05 | 08:03 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
if u search, theres a HUGE thread in the maintainance forum i think where people were sayin they had good results with the NGK plugs.
Old 10-18-05 | 12:52 AM
skperformance's Avatar
skperformance
I put iridiums in mine, no noticable difference.
Old 10-18-05 | 02:23 AM
persian451's Avatar
persian451
a lot of the member in the IS and GS forums talk about torquemaster spark plugs.. those are supposedly some of the best
Old 10-18-05 | 05:18 AM
PureDrifter
BahHumBug
CL Folding 100000
but arent those like $12-14 a pop??
Old 10-18-05 | 06:30 AM
sha4000's Avatar
sha4000
i just took my iridium out and put the ngk v-power in and besides the plugs being new im getting the same mpg and no noticeable diff.
Old 10-18-05 | 10:16 AM
persian451's Avatar
persian451
something like that
Old 10-18-05 | 11:11 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
And so are the stockers.
Old 10-18-05 | 12:14 PM
ychachad's Avatar
ychachad
As I said, go with the cheapest paltinums you can find. That is the only cost savings you'll see.
Old 10-19-05 | 05:32 PM
sradxb's Avatar
sradxb
I just bought the BOSCH Platinum 2 plugs for my ES300. Cost about $25 for 6 plugs. Are these good enough for the ES300 (it is a 1993, has 127000 miles) or should i buy the BOSCH Platinum 4?
Thanks in advance
Old 10-19-05 | 09:34 PM
nthach's Avatar
nthach
Denso PK20R-11 plugs. $6 a piece. Why mess with success. Personally, i'm not a fan of the Bosches.
Old 11-06-05 | 11:11 PM
97LS400's Avatar
97LS400
Default Iriduim plugs are a "best value"
None of the different plugs make a difference in mileage when they are new. The longevity of the plug makes a big difference over time however.
I've had my LS400 long enough to try them all; factory platinum, normal NGK copper, and Iridium. I replaced my platinum plugs at 90k and they needed it badly. The standard NGKs worked great but only for 5,000 miles. The iridium plugs still look new after 50k. I noticed that the iridium plugs have significantly reduced oxidization in the cap/rotor assemblies also. I still clean them (the cap/rotor) every 15k but they are nowhere near as bad as they used to be.
My recommendation, buy the ND or NGK iridium plugs from eBay. You can get them for about $50
Old 11-07-05 | 02:33 PM
PVSLS400's Avatar
PVSLS400
today i just put in NGK iridium IX in no difference that i can tell But box says "The benifits of NGK Spark Plugs-Lower fuel consumption-longer life-Smoother engine running - Improved ignition effeciency giving enhanced power and acceleration." We will see my LS had denso PK20R11 they worked a long time. CarQuest had them in stock and they cost 7.33 a piece
BloodlineX
IS - 1st Gen (2001-2005)
02-23-12 11:39 PM
durtysc300
Performance & Maintenance
03-18-08 08:52 AM
indypwr
GS - 1st Gen (1993-1997)
12-17-02 09:19 PM
ShowGSLuVv
05-11-02 01:42 PM
