check engine light
Old 10-22-05, 03:17 PM
tlex400
tlex400's Avatar
Default check engine light
please help when key is turn to on check engine does not come on.only when car is running light comes on/ black smoke from tail pipe at idle when reved up car won"t go past 3000rpm keeps skipping
Old 10-22-05, 08:30 PM
michael200
michael200's Avatar
Do you know how to get the check engine codes? What year is your car?
Old 10-22-05, 10:03 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Go to any Autozone or discount Auto parts, they will read your codes for free.
Pull out the negitive battery terminal for 15mins, and see if it resets anything. Sounds like your running rich for some reason. Could be an ECU problem, or an actual mechanical issue.
Old 10-23-05, 10:44 AM
tlex400
tlex400's Avatar
1993 ls400/215,000 miles when turn key to on check engine won"t come on what could be causing this/any other way to get codes. hard starting/black smoke at idle./pedal to floor car barely moves/at 3000rpm skipping
Vinaya
01-15-24 07:59 PM
dma251
03-20-10 12:51 PM
rogsc400
Performance & Maintenance
12-02-09 12:17 PM
lbq
10-29-09 05:53 PM
DroppedGS
03-16-04 12:43 PM
Quick Reply: check engine light
