Just bought LS-400 and have questions, problems :;(
Old 11-08-05, 05:58 PM
maniek_LS
maniek_LS's Avatar
Question Just bought LS-400 and have questions, problems :;(
Hi All,
Last week I bought LS-400 (I evaluated from camry 2,2 via two camry s 3.0) and now I own LS :-)
Unfortunately garage who checked car before buy doesn't find that no compression on the first (left side from radiator) cylinder :-( Tomorrow I go to authorized Toyota/lexus dealer for endoscopy of engine. I've alternative to buy used (in good condition engine) for $1k. If my engine will be damaged inside I'll replace engine.
But, my post initially was to ask you about two things. I'm looking for wiring diagram because today I saw that behind clamps (front side) there is an electric cable that goes close by shock absorber and goes to tin which covers brake plate . There is a connector and cable is cut 10cm after it.
I assume that is cable for gauge of brake pads - am I right ? Have you photo of this electric element or picture - how it looks like ?
ABS was checked on the road test - working fine - then I hope cut cable is not a ABS cable. I have no any errors (abs, check engine).
Do you have any ideas ?
Thank you
p.s. please forgive me my English
Old 11-08-05, 08:27 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by maniek_LS
Hi All,
Thank you
That wire could be for the Air struts, and the past owner might have converted to regular coils, and shocks. Does your shifter have a HEIGHT button to the left of it?
Old 11-08-05, 08:30 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Thats one hot First gen you got there... Im sure the first gen guys are drolling over the OEM front bumper, and fog lights.
Old 11-08-05, 09:02 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by MeanLex
Sounds like that wire is for your brake pad sensor not converted air struts.
I think brake sensors were added in 93... plus you would get a seperate warning light in the dash.
Old 11-09-05, 07:18 AM
sha4000
sha4000's Avatar
def. some kind of work was done
Old 11-09-05, 05:10 PM
maniek_LS
maniek_LS's Avatar
Hi,
please take into consideration that my LS is for Europe not US (European versions are most equipped - faster about one year than in car for US). My car except navigation and air suspension is fully equipped - incl. rear seats heater :-)
Today I checked - broken wire is from brake sensor. - thank you all for response.
Old 11-09-05, 05:13 PM
maniek_LS
maniek_LS's Avatar
[QUOTE=GRAND_LS 4]Thats one hot First gen you got there... Im sure the first gen guys are drolling over the OEM front bumper, and fog lights.
No, this was a standard in this (European) version of LS. I've a fog light switch on the same stick where lights are.
Old 11-09-05, 06:53 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
thats what hes talking about, OEM stands for Original Equipment Manufactorer. The fogs and bumper that are standard for your Euro-Spec model were never available here in the US.
Joelin88
07-03-18 06:10 AM
Kdfwagen
14
05-22-17 03:13 PM
MaccyD
12-05-11 03:44 AM
Quick Reply: Just bought LS-400 and have questions, problems :;(
