Repairing wood paneling on LS (front passenger)
Old 11-30-05, 03:14 PM
mmccutchin
mmccutchin's Avatar
Default Repairing wood paneling on LS (front passenger)
On my 1993 LS400. . .front passenger door. . .where the window controls reside. . .the wood panel piece is loose. . .and it looks like someone tried to clear glue it back down (doesn't look very clean though. . .almost like dried rubber cement. . .and it's not staying in place).
One of my local car friends, who services a ton of post warranty Lexuses, tells me this was a problem with the early LS models.
Could forum readers recommend how I fix this problem?
(Yes, I could take it to a dealer. . .were I to do this. . .what will they tell me. . .what will it cost. . .is there a better way to fix at home, etc?)
Thank you in advance!
Old 11-30-05, 07:05 PM
absolut
absolut's Avatar
Try this.
I had the same problem with my wood trim peeling off. I use that and haven't had any problems with them peeling since. I'd reccomend sanding off the old glue or using an adhesive remover before glueing them back on.
Old 11-30-05, 08:44 PM
PVSLS400
PVSLS400's Avatar
same problem here. cleaned up mine real well used alcohol to prime and clean then used a commercial hot glue it worked great so far!
intermec
03-02-10 05:39 AM
AlexusAnja
10-12-08 10:53 AM
Eggman
SC- 1st Gen (1992-2000)
01-16-07 02:34 PM
tommy420
10-06-04 07:36 AM
Phoenix88
06-04-03 09:05 PM
Quick Reply: Repairing wood paneling on LS (front passenger)
