Hi-Flow air for 95-97 cars...Mo?
Mo, I sent you this email. You can reply here or respond to my email. I am wanting to incorporate part of your 98+ air intake on my 97 LS400.
Do the 95-97 LS400s have the same size throttle body as the 98-00 models? If so would you consider selling just the MAF to TB pipe and TB silicon hose? If so, how much? I would need to modify it to fit my 97 which would require cutting the length and sourcing a 45 degree 3.5" ID coupling from my MAF to the tube. I would retain my stock air box and cold air ducting and replace the factory filter with a K&N (or do you recommend a different element?)
Thanks
Thanks
You may want to try ordering an HKS MAF adapter and an HKS airfilter, then fabricate your own cold air box or else see if Weapon makes a CAB one for your application.
