Can't turn steering wheel
Parked my 93' LS400 with wheels turned towrd curb. Took key out ok. When went to start car, could not turn key to start engine. Steering wheel telescopes out ok but will not turn. Could not move shift selector. Has anyone seen a similar problem??? Thank you.
Both the shifter and steering wheel are not supposed to turn unless the engine is on or the key is in the on position. Try turning the steering wheel while simultaneously turning the key in the ignition.
My 90 LS occasionally had the same problem when the brake pedal stop light switch began to fail. If I stomped on the brake pedal and played around with the ignition switch, I could usually get the steering wheel to rotate, start the car and drive away.
Replacing the brake stop light switch solved the problem on my car.
ShowGSLuVv
06-16-02 08:51 PM
