code 13
code 13
1993 ls400 215,000 miles. car starts but runs like on 4 cyclinders replaced distributor/rotors still same thing.getting code 13 from engine computer. what else could be causing this.
Originally Posted by MeanLex
Why didn't you change your spark plugs and wires?
Code 13 is a RPM signal.
If you want to reset it try resetting the ECM. If you can't find the fuse to pull the easiest way is to disconnect the battery, then go into the car and push down on the brake pedal for for about fifteen seconds (it drains all the power in the car ) then reconnect your battery.
I know but many times people can't find the correct fuse to pull so that's why I told him the battery method since everyone knows where the battery is and the brake pedal........I hope. LOL
SO THEN WHTS UP WITH MY SITUATION?
THE "ANTILOCK" AND THE "TRAC OFF" LIGHTS ARE ON WHEN I DRIVE MY 92 LS400. but when i actually lose traction the word"trac" flashes in the speedometer...this only happened once. SO IS IT THE WHEEL SENSORS OR THE OXYGEN SENSORS THAT NEED REPLACING TO GET THE TRACTION CONTROL AND ABS BACK ON TRACK> HIT ME UP ...NEED SOME CONTROL ON THESE NY ROADS
if ur trac off light is on jump tc1 and e1 and read codes
but make sure u get code 54 when u jump te1 and e1
Rokas
07-08-18 12:32 PM
