H3c foglight bulb upgrade?
VIP 様式
On the 90-94 LS 400 there are foglights in the middle which are yellow.
The bulbs say H3c on them.
Does anybody know where i can get upgrades for it so the foglights can be brighter?
My headlights have upgraded bulbs in them already,the blueish/white light is way brighter than the fogs and i need to get the fogs to match the brightness of my headlights.
Has anybody upgraded the H3c bulbs for the fogs before?
Search Function Inc.
if you replaced those bulbs yourself, you have prolly seen that its not th bulb that is yellow, but a thin glass around it that is a part of your foglight. Brake the glass to meke fogs gegular color. After that try installing a bulb with higher wattage (custom one) this way you can do it.
VIP 様式
Yeah Retrodrive i have seen that yellow glass case that surrounds the bulb.
I just want a higher upgrade for the H3c bulb so the yellow car can be brighter.
If i could find a blue H3c bulb then i would diffenetly brake the yellow fog glass case.
but i cannnot find an upgrade for this bulb H3c bulb anywhere,the H3 ones do not work becuase they have a wire to connect for the connect.
ToyotaLexus
09-30-01 06:14 AM
